Ublox gps not connecting to Navigator board. Is it not compatible?
Hello, I am trying to connect a simple Ublox gps to the navigator.
CP test run ok. actually at 32400 baud
I have used serial 3, or 5. Baud 9600 or the tested 32400. enabling and disabling Nmea.
Selecting auto, or ublox as gps type. Enabling and disbaling autodedect and auto select.
Still the navigator board doesnt see any gps module (brandnew never used).
Navigator firmware is 4.1.1 stable. Qground control 4.3.0
Please some help aprreciated
I reply to myself
ProblemSolved/
1st: Using PC and usb converter, I figured out which baudrate is liked by this Gps module (M8)
2nd:: rewire and replug to cennect to serial 3. Dont try any other serials. waste time
3rd> Disable autoselecct GPS.
Enable Auto detect model
serial port has to be Gps at same baud tested on pc
If all was correct…probably I am forgetting stuff…the inspector shoud send mavlink coordinates
Yes, in our testing the uBlox F9P is 230400 baud, as detected by MavLink / Navigator board. It shows up in the MavLink console with the baud rate, even when you have the rate set to 115200 or similar. I do think the F9P is a bit more forgiving on the rates than the M8 series, and also depends on which carrier board it is mounted to…
