hello all, i’m interested with ROV cleaning job and curious about cleaner tool like in the picture. can you guys tell me the cleaning tool that used in ROV? is there a store to buy a tool specificly for mini ROV/blueROV?
thanks all,
thanks all,
Hi @Zamzam -
I believe the disks that funciton as the cleaning element on that large ROV are cavitation cleaners, which use very high pressure water (or air? ) to create bubbles that violently explode, cleaning materials off the aquaculture HDPE tubes or ship hulls.
This takes a large fuel-powered system on the surface, something like the materials offered here. Here is video of one in action!
Hello tony, yes i believe so. Its powered by high water pressure. I also got a caviblaster to combine with the rotary dics cleaner nozzle but we need the smaller rotary nozzle maybe 100mm cleaning area. If you have suggest for theproduct just let me know
Also if you take a look on this Video , there’s a moment of the cleaner huging the pipe, is it because the suction effect of the cleaner or there’s a linear actuator to do it?. I also got another thought about it that it stick to the pipe because of back pressure from the other side(cmiiw). take a look on this back pressure rotary cleaner.
