Tether mount tutorial
Hi blue robotics enthusiasts,
Here is a simple, efficient and economical method of making an attachment point on the umbilical cable of your favorite ROV. I use it for years without any problems and i think it’s now time to share it ! :smiley:
But rather than explaining it to you with a long boring text, I did a short video …
Nice video :slight_smile:
Given your use of the soldering iron, I’m assuming your string is nylon or some other thermoplastic, and you’re sealing it so it doesn’t come apart once ‘cut’?
Thank you !
yes, you’re perfectly right, i use a nylon lacing cord, which is commonly used to tie wires harness.
What is the black “sock” material called?
Generally, these expandable braided Cable Sleeve are made of rilsan ( Polyamide ) or PET
