T2000 thruster control using Mavlink and Python
I am using Python code to control the individual thrusters of our AUV. It has 8 thrusters, 4 vertical and 4 horizontal. How can I control the thrusters manually 1 by 1, using Python code?
Also, if there is any other way to control, please mention it. I have tried several approaches, and I have also used some code I found in this community, but none of them have worked.
This is the code I was using:
from pymavlink import mavutil
import time
# Connect to Pixhawk
print(“[INFO] Connecting to Pixhawk…”)
master = mavutil.mavlink_connection(‘udpin:0.0.0.0:14550’)
master.wait_heartbeat()
print(f"[INFO] Connected to system {master.target_system}, component {master.target_component}")
# Set mode to MANUAL
mode_mapping = master.mode_mapping()
if ‘MANUAL’ not in mode_mapping:
    raise Exception("\[ERROR\] MANUAL mode not available in mode mapping.")
mode_id = mode_mapping[‘MANUAL’]
master.set_mode(mode_id)
print(“[INFO] Set to MANUAL mode.”)
time.sleep(1)
# Arm the vehicle
print(“[INFO] Arming the vehicle…”)
master.arducopter_arm()
master.motors_armed_wait()
print(“[SUCCESS] Vehicle armed.”)
# RC override array: 8 channels + 10 spares
rc_override = [1500] * 8 + [65535] * 10
# Apply forward thrust – adjust channels based on your config
# Assuming Thrusters 5 and 6 (MAIN OUT 5 and 6) = index 4 and 5
rc_override[1] = 1550  # Forward thrust
# rc_override[2] = 1550
# rc_override[2] = 1700
# rc_override[3] = 1700
print(“[ACTION] Rolling for 5 seconds…”)
start_time = time.time()
while time.time() - start_time < 8:
    master.mav.rc_channels_override_send(
        master.target_system,
        master.target_component,
        *rc_override
    time.sleep(0.1)
# # Stop motion
# rc_override[4] = 1500
# rc_override[5] = 1500
# master.mav.rc_channels_override_send(
#     master.target_system,
#     master.target_component,
#     *rc_override
# print(“[INFO] Motion stopped.”)
# Disarm the vehicle
print(“[INFO] Disarming the vehicle…”)
master.arducopter_disarm()
master.motors_disarmed_wait()
print(“[SUCCESS] Vehicle disarmed. Done.”)
WHEN I RUN THIS CODE, ALL THE VERTICAL THRUSTERS RUNS ONLY.
Hi @radwan
Ardusub does not support actuating individual thrusters like this! You can simulate user control input via higher level commands, like going up or forward, but not running each motor individually… sorry for the news! There are some “hacky” workarounds, that I would not recommend trying…. searching the forum is always a good first step!
Thank you.
Anyway can you please help me with the AUV movement? Like basic movements: Forwards, Backward, Left, Right.
Should I control all these movements using the rc_override = ___ ?
Hi @radwan
Yes, that’s correct - you command overall vehicle motion with the appropriate RC_Override commands. Can you share more about your goals for control? A lua script may be a good solution, or something with pymavlink as you’re doing…
Sorry for the late reply. So I was doing some unit testing like diving, going forward, then coming back to the surface. Here are some demo:
print(“[ACTION] 1. Diving DOWN for 4 seconds.”)
set_neutral()
rc_override[0] = 1430
rc_override[1] = 1430
# rc_override[2] = 1350
# rc_override[3] = 1350
while time.time() - start_time < 4:
send_rc_override()
time.sleep(0.1)
print(“[ACTION] 3. Moving forward for 10 seconds at 1600 PWM…”)
set_neutral()
rc_override[4] = 1600
rc_override[2] = 1520
while time.time() - start_time < 30:
send_rc_override()
time.sleep(0.1)
But the issue I am facing is that it’s moving randomly. Can you give some ideas? I am using 8 thursters, 4 horizontally 45 degree angle placed, and 4 vertical.
I am using the Bar30 pressure sensor, Pixhawk’s internal sensors.
Hi @radwan -
What mode is the vehicle in? If in Manual, it won’t automatically try to hold heading, and so can move a bit randomly without user input compensation. You may also need to calibrate your motion sensors?
This is my full code:
import time
print(“[INFO] Setting mode to STABILIZE…”)
mode_id = mode_mapping[‘STABILIZE’] # Change to STABILIZE for better control
print(“[SUCCESS] Mode set to STABILIZE”)
time.sleep(2)
# Arm the vehicle
# RC override: 8 channels + 10 unused
def send_rc_override():
"""Send the current RC override values"""
    \*rc_override
def set_neutral():
"""Set all channels to neutral position"""
for i in range(8):
    rc_override\[i\] = 1500
# MISSION SEQUENCE START
# 1. DIVING (DOWN) for 3s at 1700 PWM
set_neutral()
send_rc_override()
time.sleep(0.1)
# 2. REMAIN IDLE for 2s
print(“[ACTION] 2. Remaining idle for 2 seconds…”)
set_neutral()
while time.time() - start_time < 1:
send_rc_override()
time.sleep(0.1)
# 3. FORWARD for 5s at 1600 PWM
set_neutral()
send_rc_override()
time.sleep(0.1)
# 4. REMAIN IDLE for 2s
print(“[ACTION] 4. Remaining idle for 2 seconds…”)
set_neutral()
while time.time() - start_time < 2:
send_rc_override()
time.sleep(0.1)
# MISSION COMPLETE - STOP ALL MOTION
print(“[INFO] Mission sequence complete. Stopping all motion…”)
set_neutral()
send_rc_override()
# Clear RC override
rc_override = [65535] * 18
send_rc_override()
print(“[INFO] RC override cleared.”)
print(“[SUCCESS] Vehicle disarmed. Mission complete.”)
# Close connection
master.close()
print(“[INFO] Connection closed.”)
