T200 motor specs
I am trying to find values for specifically the T200 motor itself while it is not connected to the thruster. What is the rpm of the motor at 20 amps? What is the diameter of the axle the motor spins? It would be great to get as much information on the T200 motor as possible.
Thanks, O.R.C.A. MK2
Hi @O.R.C.A_MK2 -
Those specifications are available on the M200 product page, under Technical Details. The M200 and T200 are identical - the T200 just has a propeller and different nozzle.
  1. RPM is determined by the voltage being supplied, and the load on the motor. You can determine the max RPM, under no load, by multiplying the Kv value (rpm/volt) by the supply voltage. From there, amperage will increase as load is applied to the motor. With 470 rpm/volt, at a typical voltage of 16, you will have ~7500 rpm. Typically under load with a propeller, 3-4000 rpm is achieved.
  2. The shaft diameter is shown under 2D drawings in that section:
