Surface power supply
Greeting all. I like to use a surface power supply to the ROV as I will spend long duration under the water and do not expect the batteries to hold out for such a long time. I assume my post isn’t a new question, but I really like to know if it possible. I will be entering an environment where it would be difficult to fly back out if the battery is out of juice.
Thus, is there a cable that can support a surface power supply of 230vac and twisted pair of cores to support the data , Ethernet connections?
Why not use an ethernet over Powergrit module. But be carefull with the 230vac and Water. Only up to 48VDC is used for tools near/in water normaly.
Hi @richardo,
We have a topside power system available for the BlueROV2. This will allow you to dive your BlueROV2 indefinitely.
-Adam
thank you for the update. the topside unit is the unit in the suitcase? however I will need a stepdown unit on the vehicle won’t I? Thus what umbilical should I use?
yes I been running a system before that runs of 48vdc. Any suggestions on the POE that is available in the market? 24vdc is good for now. i assume its going to be 230vac down with the ethernet working along the two cores as well, then at the vehicle end it will be connected to a 230vac / 24vdc power supply?
Hi @richardo,
The system includes everything necessary, please read the product description in the link I posted, that will answer all your questions.
-Adam
