Hi all,
I’m looking for technical assistance with the Sonoptix ECHO RTSP raw stream:
rtsp://<sonar_ip>:8554/raw
We are seeing an issue where the raw RTSP polar video appears to contain usable sonar returns only up to approximately 10 m. Beyond ~10 m, the RTSP raw stream appears to have little or no signal, even though the sonar is configured for a longer range and the browser/WEB display shows returns farther out.
The key point is that this appears to be visible in the raw RTSP recording itself, before any Cartesian conversion or other downstream processing.
Has anyone seen similar behavior with the Sonoptix ECHO RTSP raw stream?
Specifically, I would appreciate guidance on:
Whether the RTSP raw stream is expected to contain the full configured sonar range
Whether RTSP output depends on a specific firmware version, operating mode, gain/contrast setting, or range configuration
Whether there are known differences between the WEB/VIDEO pipeline and the RTSP raw pipeline at longer ranges
Whether there are recommended settings for reliable long-range raw RTSP capture
Whether this could be related to stream scaling, H.264 encoding, gain handling, or the selected frequency/range mode
Any suggestions for what to check, log, or compare would be very helpful.
