im trying to add a slip ring to my reel setup and when i do i get a lot of lag. Should i be using a different slip ring?
Welcome,
The FathomX communication modules are pretty robust with many different sliprings we’ve tested over the years. could it be damaged. High lag and very low bandwidth is a common sign that one wire of the pair is disconnected somewhere.
Here are a few places to start:
- Check continuity with a multimeter from one end all the way to the other.
- With FathomX boards disconnected from the tether wires, measure resistance between the two wires. It should be open or at least 10M Ohms.
- Check if any other wires (especially long wires in the tether) are connected to one of the communication pair of wires.
- Did the tether you’re using work before changing the slipring?
- Is there another Fathom, VDSL, or other connection in the tether?
- Are you running power down the tether? If so, try shutting it off and using a battery to power the ROV and note the bandwidth change. Some power sources interfere with the communication rather badly.
Good luck.
