I am working on powering an ROV continuously over a long tether and would really appreciate input from anyone who has practical experience with this problem.
Specifically, I am interested in feedback on the following:
Power delivery voltage:
Has anyone successfully delivered continuous power over ~150 m tether using 230 VAC?
If so, how did you manage issues such as voltage drop, efficiency, and heat dissipation in the tether?
Alternatively, is it necessary or recommended to use higher voltage (e.g., 400 VAC or DC) to reduce losses and maintain stable supply over that length?
Power conversion on the ROV:
My ROV electronics require low voltage DC (e.g., 15 V).
Does anyone know of existing solutions, power conversion units, or so-called “power bottles” that can be mounted on the ROV to convert 230 VAC (or higher voltage) down to the required DC supply reliably?
Are there recommended products, suppliers, or manufacturers of these units?
Custom tether options:
Does anyone have experience with custom power tether solutions, or know vendors that provide specialized tethers optimized for power delivery (e.g., larger conductors, hybrid power + data lines, custom shielded assemblies) for ROV or subsea use?
Any first-hand experience, recommended suppliers, technical considerations (e.g., required cable gauge, connector standards, safety), and lessons learned would be incredibly helpful.
Hi @Henkedoodle -
Welcome to the forums!
This is a common topic - have you read some of the related threads?
Blue Robotics sells the Outland system for this application. Other vendors have solutions too!
The critical thing to remember is that AC (and DC) voltages, especially above ~30V, are INCREDIBLY dangerous! Any power over tether system needs to have proper fault-interruption circuits - using a household “GFI” is not enough - a line insulation monitor of some kind is typically used- I’ve tested with models from Bender. Vicor makes good DCDC power converters - I would avoid AC on the tether.
A simpler idea may be to keep your ROV battery power, but charge the battery at a low rate via a DC surface power supply. You still need to take care to keep the battery cells balanced, but this can be a lower budget solution that is not only safer, but cheaper to implement. The voltage drop calculator is relevant, as is this new guide!
Hello and welcome to the world of subsea robotics.
Just to reiterate what Tony mentioned: mixing electricity and water has risk. 12, 15, and 24V batteries are one thing, 48V isn’t too bad, but can be deadly under special circumstances, but 120V, 240V, and 400V can easily be fatal if the required safety features are not properly implemented. Remember “electricity wants to kill you!” I’ve worked on everything from 12V to 4,000V.
For these reasons, I would strongly recommend buying the power converter on the ROV, the surface power supply with appropriate safety features, and the high voltage tether and slip-ring as a set from a supplier such as Outland Technology or Poseidon Robotics. While you could make one a little cheaper yourself, it won’t be much cheaper if having the housings and heat sinks machined, ordering high voltage tether (usually minimum of several thousand dollars) and the few thousand dollars of safety equipment like isolated power supplies, line isolation monitors, and safety interlock circuity and high voltage DC contactors.
In answer to your questions:
Yes, you can get power across a 150m tether. We’ve done up to 250m tethers with 240VAC and over 1,000m using 400VDC. As Tony mentioned, check the voltage drop calculator to see how much power you’re going to loose in the tether and also be mindful you don’t want to overheat the conductors, especially when the tether is coiled on the reel, sitting in the sun, and there’s no cooling water.
There are a number of solutions out there, Outland being one of the best and most established, but we make similar products as well. Nearly all of them are based on parts from Vicor Power and these come in a few different flavors: Fixed output voltages (12, 14, 15, 24, and 48V). Note that the output voltage can be adjusted a small amount, but maximum power will be reduced. They also come in “fixed ratio” converters, which are much more powerful for the size, but the output voltage varies with the input voltage at the converter. These come in 8-12V, 17-24V, and 32-48V.
Standard solutions for Blue ROV power upgrade from Poseidon are:
-250VAC input with 8-12VDC output, 500-1,000W depending on tether lengeth
-400VDC input with 14VDC output, 1,200W
-400VDC input with 18VDC output (1,000W) + 24VDC output (200W) + gigabit fiber connection
While it is possible to run power over the standard Fathom Tether from Blue Robotics, Ohm’s Law limits how much power you can get down the tether, so pretty much everything we make at Poseidon from 500W to 2,000W is done over a tether with a single set of 19AWG power conductors and signals are run over a twisted pair of 26AWG conductors. For our 3,000W and 6,000W systems, we run larger tethers up to 2 sets of 16AWG wires. Many combinations can be used, but the standard Fathom reel slip-ring will not survive the high voltages, so the reel and connectors must be upgraded. We use both Linden Photonics, Inc out of Boston, MA, as well as UNIR Cable out of China, but South Bay, ROV Cable, Nexans, and many others are also excellent suppliers.
If you have a good amount of electrical experience and are determined to make your own, please feel free to reach out directly and we can point you in the right direction and would be happy to look over your design and offer pointers or identify potential hazards. It can also take a lot of time to tune the filter networks, without which the tether bandwidth may be very low due to noise, or there can be oscillations on the power converter that can cause it to fail or damage the ROV electronics.
Here’s a datasheet for our AC system we have successfully used to power Blue ROVs. It’s higher voltage than most, and the voltage can damage the Newton Gripper, so use caution, but it is one of the lower cost systems out there. If you want DC, the Outland might be a better option.
If you want 18VDC and a gigabit and aux 24V connection as well, we have our system for that know as SQUID.
It depends on the use case. Often we mix fiber optic signals or coax and have varying power levels between 500W and 6kW.
However, if just retrofitting a Blue ROV2 with a power supply of 400VDC or 240VAC and under 10A, we typically run a small slipring from SENRING in China. They will not fit inside the existing Fathom Reel without a custom housing, so we using machined Aluminum housings. You could however use 3d printed parts.
It’s important to note that outside of expensive sealed industrial sliprings, they do NOT handle much force and were not intended to be used directly: you need to make you make your own bearing and sealing system and allow the slipring to gently “float” inside the housing without any load on it.
A good tip for fiber: convert the signal from fiber to Gigabit at the rotary side of the slipring, don’t pass it through with a separate optical pass.
@PoseidonROV thanks for the info! I’ll check them out.
We’ve been using Mercotac slip rings for 3-4 years on our winch. I’ve had really good luck with them. But like you said, they aren’t made for carrying any kind of load. I machined a custom bracket out of aluminum to mount it to the side of the winch.
They make good sliprings. We just use a weaker housing design for a lower price and build our own sealed and rigid housing using o-rings, shaft seals, and large dry running bushings to handle the load. It’s held together with a snap ring and metal washer with PTFE washer between to avoid wear.
You can 3d print the two housings and end caps in a strong material and insert the bearings and they hold up good for small hand operated winches.
I’ve been building and running work-class ROVs for a couple years, including some with 150-200m tethers. Totally get the headache you’re dealing with.
On the 230 VAC thing: yeah, I tried it first and it sucked. Voltage drop was like 15-20V under full load, efficiency tanked around 75%, and the tether got warm enough I was worried about insulation. Switched to 400 VAC and it was night and day—way less current, minimal drop, almost no heat. If you can swing it, go 400 VAC or even 300-400 VDC. DC is cleaner for long runs if your topside supply supports it.
Power conversion on the ROV: I mount a sealed “power bottle” right on the frame. Took a commercial AC-DC module (Vicor or similar ruggedized one) and potted it in epoxy inside an aluminum housing. Handles 230/400 VAC straight down to stable 15 VDC at 100-200W no sweat. Super reliable underwater. If you want something cheaper and already subsea-rated, hit up some Chinese suppliers—they make off-the-shelf units that bolt on easy.
Custom tethers: I went with a hybrid power+data cable, 4 AWG or thicker copper for the power lines to keep resistance low. Added shielding for data and used proper strain relief. For connectors, I bought from HYSF SUBSEA (Chinese company). Their underwater connectors are legit—IP68, handle 400V easy, no leaks after months of dives. Way cheaper than the big European brands but zero issues on my last two builds. They even helped spec the pinout for my tether.
Lessons: calculate your cable gauge based on total amps (I use an online voltage drop calculator), always add a ground wire, and pressure-test the whole thing before the first dive. Heat is the silent killer—keep power under 70% of cable rating.
