Hi everyone
Due to the difficulty of access, I would like to remove a screw fixing the engine (see the image) but leaving the other three.
Will this be a big security problem ?
Thanks for your help,
That leaves it almost 180 degrees unsupported. I think you’d be turning over the hourglass-of-failure if you removed it and the speed in which is fails would be directly related to your gain and throttle usage.
Ok, but I don’t want to remove the feet, only the screw.
