How do you guys solve the rotary slip ring issue with fiber optic on the reel? Slip rings for fiber optic are insanely expensive. Another question, is it possible to have such fiber optic tether easily detachable from the ROV without having to use penetrator which would have to be un-screwed every time, and seals replaced after some time? It is possible to make some kind of easily plug-able connector at the bulkhead for fiber?
Hi @laukejas, welcome to the forum ![]()
This comment from another thread is likely relevant:
I’m not aware of any available options for this, but it’s also not an area I’m experienced in, so it’s possible there’s something I don’t know about. In general, many things are possible in theory but may not be readily available and affordable, and may not be robust enough to be a good idea.
From a theoretical standpoint the primary requirements of such a connector would be:
- keeps water out when connected (dry mate-able)
- this is likely feasible, but would probably require some form of locking sleeve, and a seal that gets replaced from time to time
- ideally it would also keep water out when disconnected / if the tether gets cut (wet mate-able)
- if there’s a marine epoxy that bonds well enough to the fiber this could work, in which case a replaceable seal may not be required
- provides a sufficiently good optical connection
- as Etienne described above, the low requirements of a general ROV use-case compared to the optimal capacity of the fiber itself mean that this could be ok (using the “fast” termination method, since the other methods form more permanent connections)
- the connector would likely need some form of locating and/or clamping feature(s), for repeatable alignment and contact between the fibers
- this could be quite challenging to do robustly, in a way that ensures good contact between the fibers while also avoiding damaging them
- some form of protection and/or regular checks and maintenance to ensure the fibers do not get damaged while they are disconnected, and to prevent/remove any particulate matter (e.g. dust, salt, etc) that could block the light path
- maintenance for this could be challenging to avoid damaging the fibers
Hi, @EliotBR, and thatnk you for the info! Regarding that bailing reel, that would be a very nice solution indeed. Sad that the guy in that topic you linked to, got robbed before he could take any pictures. I am still not sure how it would work. I mean, I know I could bail the tether manually by wrapping it around the reel, but I wonder if there is any way to automate it without going crazy technical so the tether could be wound with a crank or something. Is there anyone else who has done this? A few pics for reference would help a lot.
I looked into the connector that @Boko linked to - the fact that they don’t advertise the price, says a lot
I need to make some research and maybe some experiments to see if I can build such a connector myself - I have a 3D printer and access to a metal lathe. Although I am still not sure how that would such connector integrate into the end cap. I build my end caps myself, and since the rest of my electrical setup is with copper, I usually just embed copper rods in plastic end cap with epoxy, soldering wires to the ends of the rods. Embedding a fiber optic connector into the end cap would be very difficult, and risky (if the embedded part of fiber breaks, the whole end cap is ruined). I wonder if I could simply embed a glass/acrylic “window” into the end cap, with fully removable connectors on each side, so that the fiber light could shine through that window? If aligned well enough, that should work, right?
Also, what happens if water gets inside the fiber optic cable? Does that ruin it completely, or just worsens the signal? I don’t think that could be avoided with DIY fabrication means.
Hi, @laukejas, My setup has the fiber media converter inside a waterproof box (red) mounted in the middle of the reel. A gigabit slipring with some extra conductors for the high voltage power to the vehicle and low voltage to power the media converter. I’ve run this for years with no issues. The subsea side has a 2" BlueRobotics WTE with the media converter inside it, and two BlueTrail Engineering cables connecting gigabit LAN, and HV power to the vehicle power supply. Sorry the photos are pretty rough.
MacArtney has told me they are working on a hybrid fiber connector for this use. Will keep my eye out for that.
Cheers,
Ken
I’m not particularly familiar with different fishing reel mechanisms, but I searched online for how the mentioned mechanism works and found this description and this video to be the most immediately informative results that I came across, and this page shows some pictures of internals.
A further search along the lines of “spinning reel mechanism internals” may prove fruitful if you’re after additional information (there may be some useful diagrams in an image search) - less specific searches tend to yield results centred around what to consider when buying or operating a fishing reel.
Thanks for sharing! Your subsea converter side is larger than my entire ROV
But it makes sense. Complicated, but avoids slip rings.
Thank you for sharing these links. The mechanism seems extremely complicated, I am not sure how it could be made on a large scale, especially the part that ensures the tether is wound uniformly along the width of the reel. I wrote to Daryll (from the first link you gave), perhaps he will share his solution.
Hi Etienne,
Can you please share the steps of converting the Fathom-X to fiber optic? here is my email ssaravin@gmail.com
Hi, i tried replacing the Fathom X with ethernet to fibre converter. But there is no communication received at the topside. Can you some input on what are the possible causes?
hi matt, i would like to see some post or pictures of your fiber setup, also what BiDi module did you use for your tether? i appreciate your knowledge feel free to email me. mccully.cris@gmail.com TIA !
I was thinking that I had something to add to the forum in this regard.
We were of to a project the other day to recover some hydrophones. Could not get the Cameras to work. When we hooked it up without the tether sub worked fine with two HD cameras, original and a DWE.
We did the job without the bluerov copper slipring and running on one camera in low res.
Two weeks after this issue was completely gone.
We now have another vehicle that is fibre converted. I have measured a mean bandwith of 940Mbit.
Parts used:
2 x GigaBlox SFP - Compact 6 Port Ethernet Switch with SFP
BiDi SFP, a compatible pair of these to chuck into each switch…
Greene tweed Bulkhead, these comes in 3/8 -24, we centralized it in a 10mm hole of the BlueROV2 and put a nut. It worked for 100m But I would not recommend anyone else to try. We are in the market for fiber bulkheads with M10 or we need to custom our own flange. There have been chinese workshops willing to manufacture one for a decent sum.
Linden photonics tether, its price is around 10-12 USD/m, we had a 3,5 mm anti kink, seems good quality.
Found a kellems that worked down to 6mm, added vulctape to build it up, seem fine.
Did I say that our slip ring had not arrived in time, we used traffic cones. Slipring price around 500USD
Then later an exhaust hose bent in 90degrees instead of a traditional block, no risk of jumping over the wheel…
Things to be improved =)
We did experience lag in the video of our DWEs, especially the global shutter camera. Looking into it at the moment. Hoping to be able to receive MJPEG with this bandwidth.
I hope someone could have some use of this info, shout out for optional handy bulkheads please!
We use a BueOS-based rover for pipeline inspection and underground culverts. Just did one about 1 kilometer long and 25 feet underground. Due to the distance, we use fiber, single-mode OS2 tactical fiber with a TPU jacket. It gets dragged behind what is effectively a competition-class 1/6-scale rock crawler; it lives a very hard life. We just use these mini fiber media converters from AliExpress. I have two types: a set with SC connectors and a pair with SFP ports for transceivers. It appears the mini converters on Amazon are the same boards, just wrapped up in a metal case with a USB-C port instead of a DC jack. It was pretty easy to put into our rover housing, which is roughly the same dimensions os the BlueRov2 housing. The photo below is for the SC style connectors; they do make an SFP style as well, and those seem more common on Amazon.
We sell fiber upgrade kits, fiber tethers and fiber spools for BlueROV2’s. The longest distance we’ve inspected with a BR2 was 2kms.
