ROV-based benthic imaging - thoughts?
A long overdue update on this thread from me. I wanted to bring you up to date on where we ended up on the Benthic Imaging project as I know others are attempting similar applications.
  1. Camera choices: Due to the close nature (<1m from the seafloor), we ended up going for a global shutter GigE Machine Vision Camera (Sony Pregius IMX304 12Mpx). At 1.1", the sensor in this camera is the largest you can really use while maintaining a small form factor C-mount lens. Pros: Ease of integration (physical and software); axial form-factor (cables align with lens) for tubes; great colour balance and ok sensitivity. Cons: no autofocus - a pain with dome. Conclusion: Happy with results. With more time would like to evaluate some of the newer specialised drone cameras, like the full-frame Sony ILX-LR1 (Exmor R) with autofocus lens.
  2. Optics: Dome port required with wide angle to prevent bluring around the edges. Ended up using the 4" BR dome port. Pros: Low cost; off the shelf; Cons: virtual image is curved so requires depth of field to maintain focus, so trade off between maintaining depth of field needed with shutter speed. Conclusion: Larger diameter, non hemisherical dome would work better.
3 Lighting: A team at the University of Canterbury, NZ, were developing a similar platform, and had already developed a COB LED strobed lighting solution that works from an external power source (BlueROV2 power). They were happy to supply us with one of their units. Pros: Works off a single power supply; lightweight; Cons: None.
4. Mechanical: We considered using the BR skid, but couldn’t see how we’d fit an enclosure for a downward mounted camera. The solution we came up with is a trailer arrangement - the “Caboose”. See this thread. Pros: Maintains single person launch / retrieval (just!); lower drag in forward direction; Cons: $$$ custom engineering to make it work; 1L box heavy so a lot of bouyancy needed compensate; impacts sideways and up/down driving dynamics (but tollerable); Next steps: Will try a 4" tube instead of the box+tube. Bulkier but less bouyancy needed. Skid would be worth revisiting, but would require custom, shorter 4", 5" downtubes, or different form factor camera enclosure (non-axial cameras).
5 Software: RPs are cheap so we decided to make the camera software stand-alone and with it’s own web interface. We are taking stills imagery, and recording geolocation (using surface GPS + DVL) and essential telemetry in EXIF on the fly. At the moment we software trigger purely based on timing (a set fps). In the future we might look at a distance based triggering. A simple interface with preview/record/status functionality is IFRAME’d in Cockpit. Pros: no load on BlueROV2 companion computer. Cons: Added space and complexity of 2nd RP.
Some product opportunities for BlueRobotics:
  • Non-hemispherical, larger diameter optical dome -OR- pick a cost-effective optical dome supplier (or 2), e.g. Ikelite, and engineer a compatiable flange plate for BR tubes and their domes.
  • Combine with short 4", 5", 6" enclosures. Something that would fit in applications of downward-looking cameras with the skid.
  • Add high output strobe lights to the BR lighting range for underwater stills photography / photogrammetry, i.e. ones that utilise the ROV power supply and don’t need their own batteries.
Some sample images attached.
