Research on ROV visual autonomous obstacle avoidance navigation based on deep learning
When I use the game controller, everything works fine (forward, backward, left and right movement, and yaw).
Hi @akang-211 -
Is that true in stabilize or depth hold mode?
No, the code is not adjusted to stable mode or depth hold mode, or do you mean that the code needs to be tested in stable mode or depth hold mode?
Hi @akang-211 -
I suggest you try operating the vehicle normally more, and experimenting with the difference in response to user control changing modes can have. You’ll find that in stabilize or depth hold mode, the vehicle automatically works to stabilize itself (in the roll axis for your 6 thruster vehicle), and maintain a constant heading. By operating in this mode in your code, you can command heading, and provide virtual pilot input that has the expected desired affect. It seems possible that the behavior you’re seeing from your code is expected for manual operation with static control inputs…
This is my latest test video. I tested it under stabilize with pwm parameters of 5,1550. It should move forward and backward, but why did it rotate? I also set the parameters to 6,1550 and the same action happened.
I used the sample code, but the ROV did not respond.
from builtins import object
import weakref
from time import sleep
from threading import Thread, Event, Lock
from pymavlink import mavutil
import pymavlink.dialects.v20.ardupilotmega as mavlink
class WriteLockedFile(object):
    """ A file with thread-locked writing. """
    def __init__(self, file):
        self._base_file = file
        self._write_lock = Lock()
    def write(self, *args, **kwargs):
        with self._write_lock:
            self._base_file.write(*args, **kwargs)
    def __getattr__(self, name):
        return getattr(self._base_file, name)
    def __dir__(self):
        return dir(self._base_file) + ["_base_file", "_write_lock"]
class mavactive(object):
    """ A class for managing an active mavlink connection. """
    def __init__(self, connection, type_=mavlink.MAV_TYPE_GENERIC,
                 autopilot=mavlink.MAV_AUTOPILOT_INVALID, base_mode=0,
                 custom_mode=0, mavlink_version=0, heartbeat_period=0.95):
        """ Initialises the program state and starts the heartbeat thread. """
        self.connection = connection
        self.type = type_
        self.autopilot = autopilot
        self.base_mode = base_mode
        self.custom_mode = custom_mode
        self.mavlink_version = mavlink_version
        self.heartbeat_period = heartbeat_period
        # replace internal file with a thread-safe one
        self.connection.mav.file = WriteLockedFile(self.connection.mav.file)
        # set up the kill event and initialise the heartbeat thread
        self._kill = Event()
        self._finalizer = weakref.finalize(self, self.kill)
        self._birth()
    def _birth(self):
        """ Creates and starts the heartbeat thread. """
        self._kill.clear()
        self.heartbeat_thread = Thread(target=self.heartbeat_repeat)
        self.heartbeat_thread.daemon = True
        self.heartbeat_thread.start()
    @property
    def is_alive(self):
        return not self._kill.is_set()
    def heartbeat_repeat(self):
        """ Sends a heartbeat to 'self.connection' with 'self.heartbeat_period'. """
        while self.is_alive:
            self.connection.mav.heartbeat_send(
                self.type,
                self.autopilot,
                self.base_mode,
                self.custom_mode,
            sleep(self.heartbeat_period)
    def kill(self):
        """ Stops the heartbeat, if not already dead. """
        if not self.is_alive:
            return # already dead
        self._kill.set()
        self.heartbeat_thread.join()
        del self.heartbeat_thread
    def revive(self):
        """ Starts the heartbeat, if not already alive. """
        if self.is_alive:
            return # already alive
        self._birth()
#!/usr/bin/env python3
import time
import weakref
from numbers import Number
from functools import partial
from itertools import repeat, chain
from contextlib import contextmanager
from mavactive import mavactive, mavutil, mavlink
# logging setup
import logging
logging.NOTE = logging.INFO - 5
logging.addLevelName(logging.NOTE, 'NOTE')
class NoteLogger(logging.getLoggerClass()):
    def note(self, msg, *args, **kwargs):
        if self.isEnabledFor(logging.NOTE):
            self._log(logging.NOTE, msg, args, **kwargs)
logging.setLoggerClass(NoteLogger)
logging.note = partial(NoteLogger.note, logging.getLogger())
class Autopilot:
    """ An ArduSub autopilot connection manager. """
    def __init__(self, *args, client=True, thrusters=6, **kwargs):
        self.thrusters = thrusters
        self.master = mavutil.mavlink_connection(*args, **kwargs)
        if client:
            logging.debug('connecting to MAVLink client...')
            self.master.wait_heartbeat()
        else:
            logging.debug('connecting to MAVLink server...')
            self._server_wait_conn()
        logging.info('MAVLink connection successful')
        # send regular heartbeats, as a ground control station
        self.heart = mavactive(self.master, mavlink.MAV_TYPE_GCS)
        self._finalizer = weakref.finalize(self, self.cleanup)
        # convenience
        self.mav = self.master.mav
        self.recv_match = self.master.recv_match
        self.target = (self.master.target_system,
                       self.master.target_component)
        logging.debug('checking for autopilot...')
        self._wait_autopilot_heartbeat()
        logging.info('connection to autopilot confirmed')
    def _server_wait_conn(self):
        while 'waiting for server to respond':
            self.master.mav.ping_send(int(time.time() * 1e6), 0, 0, 0)
            if self.master.recv_match():
                break
            time.sleep(0.5)
    def _wait_autopilot_heartbeat(self):
        ensure_autopilot_heartbeat = (
            f'HEARTBEAT.get_srcSystem() == {self.master.target_system} and '
            f'HEARTBEAT.get_srcComponent() == {mavlink.MAV_COMP_ID_AUTOPILOT1}'
        self.recv_match(type='HEARTBEAT', condition=ensure_autopilot_heartbeat,
                        blocking=True)
    def read_param(self, name: str, index: int = -1, timeout: float = None):
        self.mav.param_request_read_send(
            *self.target,
            name.encode('utf8'),
            index
        logging.note(f'read_param({name=}, {index=}, {timeout=})')
        return self.recv_match(type='PARAM_VALUE', blocking=True,
                               timeout=timeout)
    def set_param(self, name: str, value: float, type: int = 0,
                  timeout: float = 1, retries: int = 3):
        name = name.encode('utf8')
        self.mav.param_set_send(
            *self.target,
            name, value, type
        logging.info(f'set_param({name=}, {value=}, {type=})')
        while not (msg := self.recv_match(type='PARAM_VALUE', blocking=True,
                                          timeout=timeout)) and retries > 0:
            retries -= 1
            logging.debug(f'param set timed out after {timeout}s, retrying...')
                *self.target,
                name, value, type
        return msg
    def __enter__(self):
        ''' Send regular heartbeats while using in a context manager. '''
        logging.info('__enter__ -> reviving heart (if required)')
        self.heart.revive()
        return self
    def __exit__(self, *args):
        ''' Automatically disarm and stop heartbeats on error/context-close. '''
        logging.info('__exit__ -> disarming, and stopping heart')
        self.cleanup(disconnect=False)
    def arm(self):
        self.master.arducopter_arm()
        logging.debug('arm requested, waiting...')
        self.master.motors_armed_wait()
        logging.info('Motors armed!')
    def disarm(self):
        self.master.arducopter_disarm()
        logging.debug('disarm requested, waiting...')
        self.master.motors_disarmed_wait()
        logging.info('Motors disarmed')
    def set_mode(self, mode):
        ''' Sets autopilot 'mode', by name or id number. '''
        if isinstance(mode, str):
            for attempt in range(5):
                if (mapping := self.master.mode_mapping()):
                    break  # success - mapping available
                logging.info('mode mapping not available, retrying...')
            else:
                logging.warning('mode change failed - no mapping available!')
                return
            mode_id = mapping[mode.upper()]
        else:
            mode_id = mode
        self.master.set_mode(mode_id)
        logging.debug(f'setting {mode=} ({mode_id=}), waiting...')
        while 'mode change not confirmed':
            ack_msg = self.recv_match(type='COMMAND_ACK', blocking=True)
            # check if acknowledged MAV_CMD_DO_SET_MODE or SET_MODE (old)
            if ack_msg.command in (176, 11):
                if ack_msg.result == 0:
                    logging.info(f'{mode=}, change successful')
                else:
                    result = mavlink.enums['MAV_RESULT'][ack_msg.result]
                    logging.warning('mode change failed!\n\t%s: %s',
                                    result.name, result.description)
                break
    def set_servo(self, servo, pwm):
        ''' Set a single servo output pwm value.
        'servo' can only be outputs that aren't assigned as motors, so is
          generally used for lights/camera etc.
        When in a per_thruster_control context in Servo mode, also allows
          controlling individual thrusters.
        logging.info(f'set_servo({servo=}, {pwm=})')
        self.master.set_servo(servo, pwm)
    def send_rc(self, rcin1=65535, rcin2=65535, rcin3=65535, rcin4=65535,
                rcin5=65535, rcin6=65535, rcin7=65535, rcin8=65535,
                rcin9=65535, rcin10=65535, rcin11=65535, rcin12=65535,
                rcin13=65535, rcin14=65535, rcin15=65535, rcin16=65535,
                rcin17=65535, rcin18=65535, *,  # keyword-only from here
                pitch=None, roll=None, throttle=None, yaw=None, forward=None,
                lateral=None, camera_pan=None, camera_tilt=None, lights1=None,
                lights2=None, video_switch=None):
        ''' Sets all 18 rc channels as specified.
        Values should be between 1100-1900, or left as 65535 to ignore.
        Can specify values:
            positionally,
            or with rcinX (X=1-18),
            or with default RC Input channel mapping names
              -> see https://ardusub.com/developers/rc-input-and-output.html
        It's possible to mix and match specifier types (although generally
          not recommended). Default channel mapping names override positional
          or rcinX specifiers.
        rc_channel_values = (
            pitch or rcin1,
            roll or rcin2,
            throttle or rcin3,
            yaw or rcin4,
            forward or rcin5,
            lateral or rcin6,
            camera_pan or rcin7,
            camera_tilt or rcin8,
            lights1 or rcin9,
            lights2 or rcin10,
            video_switch or rcin11,
            rcin12, rcin13, rcin14, rcin15, rcin16, rcin17, rcin18
        logging.info(f'send_rc')
        logging.debug(rc_channel_values)
        self.mav.rc_channels_override_send(
            *self.target,
            *rc_channel_values
    def clear_motion(self, stopped_pwm=1500):
        ''' Sets all 6 motion direction RC inputs to 'stopped_pwm'. '''
        logging.info('clear_motion')
        self.send_rc(*[stopped_pwm] * 6)
    def get_thruster_outputs(self):
        ''' Returns (and notes) the first 'self.thrusters' servo PWM values.
        Offset by 1500 to make it clear how each thruster is active.
        logging.debug('get_thruster_outputs')
        servo_outputs = self.recv_match(type='SERVO_OUTPUT_RAW',
                                        blocking=True).to_dict()
        thruster_outputs = [servo_outputs[f'servo{i + 1}_raw'] - 1500
                            for i in range(self.thrusters)]
        logging.note(f'{thruster_outputs=}')
        return thruster_outputs
    def status_loop(self, duration, delay=0.05):
        ''' Loop for 'duration', with 'delay' between iterations. [s]
        Useful for debugging.
        start = time.time()
        while time.time() - start < duration:
            self.get_thruster_outputs()
            time.sleep(delay)
    def command_long_send(self, command, confirmation=0, param1=0, param2=0,
                          param3=0, param4=0, param5=0, param6=0, param7=0):
        self.mav.command_long_send(
            *self.target,
            getattr(mavlink, f'MAV_CMD_{command}', command),
            confirmation,
            param1, param2, param3, param4, param5, param6, param7
    def set_message_interval(self, message, interval, response_target=0):
        ''' Set message interval, as per MAV_CMD_SET_MESSAGE_INTERVAL.
        Required to get specific messages if not auto-streamed by connection.
        'message' is the name or id of the message
        'interval' is the desired interval [us]
        logging.info(f'set_message_interval({message=}, {interval=})')
        self.command_long_send(
            'SET_MESSAGE_INTERVAL',
            param1=getattr(mavlink, f'MAVLINK_MSG_ID_{message}', message),
            param2=interval, param7=response_target)
    def set_bulk_message_intervals(self, messages, interval=None):
        ''' Set several message intervals at once. '''
        if interval is None:
            if isinstance(messages, dict):
                iterator = messages.items()
            else:
                # assume iterator of pairs
                iterator = messages
        elif isinstance(interval, Number):
            iterator = zip(messages, repeat(interval))
        else:
            iterator = zip(messages, interval)
        for message, interval in iterator:
            self.set_message_interval(message, interval)
    def disconnect(self):
        ''' End the MAVLink connection. '''
        logging.info('disconnect -> closing MAVLink connection')
        self.master.close()
    def cleanup(self, *, disconnect=True):
        ''' Attempt to disarm, then stop sending heartbeats.
            Optionally disconnect (true by default).
        try:
            self.disarm()
        except OSError:
            pass
        self.heart.kill()
        if disconnect:
            self.disconnect()
    @classmethod
    def connect_to_client(cls, ip='0.0.0.0', port=14550, *args, **kwargs):
        ''' Default for topside connection to Blue Robotics Companion/BlueOS. '''
        logging.note(f'connect_to_client({ip=}, {port=}, {args=}, {kwargs=})')
        return cls(f'udpin:{ip}:{port}', *args, **kwargs)
    @classmethod
    def connect_to_server(cls, ip='blueos.local', port=14550, *args, **kwargs):
        ''' Less network configuration required, but seemingly less robust. '''
        logging.note(f'connect_to_server({ip=}, {port=}, {args=}, {kwargs=})')
        return cls(f'udpout:{ip}:{port}', *args, **kwargs, client=False)
class ExtendedAutopilot(Autopilot):
    ''' An Autopilot with extended control functionality. '''
    SERVO_OUTPUT_FUNCTIONS = {
        'Disabled': 0,
        'RCPassThru': 1,
        **{f'Motor{i}': param_value for i, param_value in
           enumerate(chain(range(33, 33 + 8), range(82, 82 + 4)), start=1)},
        **{f'RCIN{i}': param_value for i, param_value in
           enumerate(range(51, 51 + 16), start=1)},
    @contextmanager
    def per_thruster_control(self, mode='Servo', stopped_pwm=1500,
                             backup_timeout: float = None,
                             set_timeout: float = 1, set_retries: int = 3):
        ''' Allow thrusters to be controlled individually, within a context.
        WARNING: while in context, thruster actions no longer require arming,
          and failsafes are no longer engaged!
        'mode' can be 'Servo' (default) or 'RCPassThru' to control thrusters
          either using self.set_servo, or using self.send_rc.
        WARNING: if the vehicle is powered down while in RCPassThru mode the
          thrusters may become active WITHOUT ARMING on next power up, from
          joystick input. It is more powerful than Servo mode because multiple
          thrusters can be controlled in a single function call, but use with
          significant caution.
        For vehicles with more than 6 thrusters RCPassThru mode is not
          recommended, because it doubles-up on existing RC Input mappings
          (e.g. Camera Pan and Tilt are mapped to inputs 7 and 8). That issue
          can be worked around if necessary by mapping individual outputs to
          only otherwise unused RCINx inputs (generally 1-6, 12-18), but that's
          not currently supported/implemented by this function.
        Another alternative is remapping the input channels with PARAM_MAP_RC,
          although that can cause some difficult debugging issues when
          comparing behavior to BR documentation/examples, which assumes the
          default mappings.
        logging.info('Engaging per-thruster control!')
        logging.warning('Thruster actions no longer require arming!')
        logging.warning('Failsafes no longer engaged!')
        if mode == 'RCPassThru':
            output_function = self.SERVO_OUTPUT_FUNCTIONS[mode]
            logging.critical('RCPassThru mode engaged:\n'
                             ' -> THRUSTERS RESPOND DIRECTLY TO RC/JOYSTICK INPUTS')
        elif mode == 'Servo':
            output_function = self.SERVO_OUTPUT_FUNCTIONS['Disabled']
            logging.info('Servo mode engaged:\n'
                         ' -> control thrusters with self.set_servo')
        else:
            raise ValueError(f'Invalid per-thruster control {mode=}')
        self._backup_servo_functions(backup_timeout)
        try:
            # try to make sure thrusters are stopped before changeover
            self._stop_thrusters(mode, stopped_pwm)
            # set first n SERVO outputs to passthrough first n RC inputs
            for n in range(1, self.thrusters + 1):
                self.set_param(f'SERVO{n}_FUNCTION', output_function,
                               timeout=set_timeout, retries=set_retries)
            # make sure thrusters are actually stopped
            yield self
        finally:
            # make sure to stop thrusters before changing back
            self._restore_servo_functions(set_timeout, set_retries)
        logging.info('per-thruster control successfully exited')
        logging.warning('Arming and failsafe requirements re-engaged')
    def _stop_thrusters(self, mode, stopped_pwm):
            self.send_rc(*[stopped_pwm] * self.thrusters)
        else:
            for servo in range(1, self.thrusters + 1):
                self.set_servo(servo, stopped_pwm)
    def _backup_servo_functions(self, timeout: float = None):
        logging.note('backing up servo thruster functions')
        self._old_servo_functions = {}
            param = f'SERVO{n}_FUNCTION'
            self._old_servo_functions[param] = self.read_param(param)
    def _restore_servo_functions(self, timeout: float = 1, retries: int = 3):
        for param, backup in self._old_servo_functions.items():
            self.set_param(param, backup.param_value, backup.param_type,
                           timeout, retries)
        logging.note('servo functions restored')
def configure_logging(level, filename, datefmt):
    # configure logging, based on defaults/user input
    log_level = getattr(logging, level)
    logging.basicConfig(filename=filename, level=log_level, datefmt=datefmt,
                        format=('%(levelname)s: %(asctime)s.%(msecs)03d - '
                                '%(message)s'))
if __name__ == '__main__':
    # 作为一个脚本运行
    # 设置一些有用的命令行参数
    from argparse import ArgumentParser
    parser = ArgumentParser()
    parser.add_argument('-l', '--log', default='note',
                        help=('Lowest importance level to log '
                              '(debug/note/info/warning/error/critical)'))
    parser.add_argument('-f', '--filename', default='',
                        help=('File to log to - '
                              'prints to console if not specified'))
    parser.add_argument('-d', '--datefmt', default='%H:%M:%S',
                        help='datetime format for logging')
    parser.add_argument('-m', '--mavlink', default='udpin:0.0.0.0:14550',
                        help='MAVLink connection specifier')
    parser.add_argument('-r', '--request', action='store_true',
                        help='Connection requires messages to be requested')
    args = parser.parse_args()
    client = args.mavlink.startswith('udpin')
    configure_logging(args.log.upper(), args.filename, args.datefmt)
    # 运行/测试所需的功能
    print('If script gets stuck, press CTRL+C to disarm and quit\n')
    with Autopilot('udpin:0.0.0.0:14550', client=True) as sub:
        sub.set_mode('MANUAL')
        sub.clear_motion()
        sub.arm()
        sub.send_rc(forward=1600)  # 前进
        time.sleep(3)
        sub.clear_motion()
        sub.send_rc(lateral=1600)  # 右移
        time.sleep(3)
        sub.clear_motion()
        sub.send_rc(throttle=1600)  # 上升
        time.sleep(3)
        sub.clear_motion()
    with Autopilot(args.mavlink, client=client) as sub:
        if args.request:
            # 请求 5Hz 的 SERVO_OUTPUT_RAW
            sub.set_message_interval('SERVO_OUTPUT_RAW', 2e5)
        sub.get_thruster_outputs()
        # 确保在布防前所有动作都设置为静止
        sub.clear_motion()
        sub.arm()
        # 设置一些横滚
        sub.send_rc(roll=1700)
        sub.status_loop(1)
        # 加大油门
        sub.status_loop(1.5)
    # 解除武装并等待一会
    time.sleep(5)
    # 重复输入
    with sub:
        logging.info('RE-ENTERING')
        sub.set_mode('stabilize')
        sub.clear_motion()
        sub.arm()
        # set yaw velocity and some forward motion at the same time
        sub.send_rc(yaw=1800, forward=1600)
        sub.status_loop(2)
    # 断开连接并等待一会
    sub.disconnect()
    time.sleep(5)
    # 重新连接, 并增强控制模式
    with ExtendedAutopilot(args.mavlink, client=client) as e_sub, \
            e_sub.per_thruster_control():
        # 显示推进器初始化的值
        e_sub.get_thruster_outputs()
        # 设置一些推进器的值
        e_sub.set_servo(1, 1300)
        e_sub.status_loop(1)
        e_sub.set_servo(3, 1400)
        e_sub.set_servo(4, 1550)
        e_sub.status_loop(1.5)
I added a binocular camera to my ROV, and it sank to the bottom of the pool (it was loaded on the surface before I added the camera). How can I make the ROV float after adding the camera? I tried depth hold mode, and it flipped over.
Hi @akang-211,
Can you please try controlling your vehicle using QGroundControl or Cockpit (instead of your custom code), and seeing whether stabilise and depth hold mode work as expected?
If they don’t then it’s likely there’s a problem with your configuration or hardware, which you should definitely confirm before trying to do custom programmatic control.
If there are issues there then please try putting your vehicle in the pool, and running the “Detect Reversed Motors” functionality in BlueOS. It’s possible that will fail, which could indicate your vehicle’s weight distribution is quite unbalanced, or there’s a problem with one or more of your thrusters, or it could mean your thrusters are not connected in the sequence expected by the frame (which you should be able to check with the manual motor test functionality in BlueOS - the motor moving in a given test should match the one highlighted in the 3D model).
Once you’re certain the thrusters are mapped and configured correctly, check again that depth hold and stabilise modes are working as expected when controlled with a joystick. From there you can try your code again, and we can try to have a productive discussion around any issues you run into.
Nice work! Try removing the weight attached to the frame directly underneath the camera. If it doesnt become neutrally bouyant then adjust the other weights.
Actually just noticed that you have a separate cable going to the camera that appears to be negatively bouyant. This would mean that the deeper you go (more cable) the heavier the ROV is going to be. Is it not possible to use the spare lines in the original tehter cable to operate the camera??
是的,我已经将前面下方的铁块去掉了一个,现在可以保持正常浮力了。你提到的那个线缆其实是双目相机的线缆。
Yes, I have removed one of the iron blocks at the bottom front, and now it can maintain normal buoyancy. The cable you mentioned is actually the cable for the binocular camera.
How can I know the changes in the ROV’s heading angle when I use the joystick to operate it?
