Hi
i was wondering is possible send a message by pymavlink to start/stop record video?
in case were i will go to see the video after?
Hi @fusari,
Unless you have a MAVLink-enabled camera that supports onboard recording then pymavlink is unrelated to the video stream. If you want to programmatically start/stop video recording then you’ll need to create or use a program that can do that (likely using ffmpeg or gstreamer or similar), in which case the saved videos will be wherever you decide to put them ![]()
