mmkk15
(Mike)
August 18, 2019, 4:02pm
1
I followed the installation instruction from here: Setup the Build Environment on Windows — Dev documentation
and so far everything worked fine.
I checked out the firmware and switched to branch Sub-3.5.
Configuring with waf was smooth, but compiling fails - see here:
https://pastebin.com/GHp0fv73
Any ideas or comments what I’m doing wrong?
best regards,
Mike
mmkk15
(Mike)
August 18, 2019, 7:14pm
2
Hi all,
I tested an tried to get further to the problem and now I found that it seems that the module PX4Firmware is missing. But I’m sure it’s there … see:
Any help’s really appreciated!
Thanks in advance,
Mike
After changing the branch to Sub-3.5, have you done the update of the submodules ?
git submodule update --init --recursive
mmkk15
(Mike)
August 19, 2019, 5:49pm
4
Hi Patrick,
thanks a lot for your quick response!
I’ve tried again the full process, also with the initialization of the submodules. See the log here:
https:// pastebin.com/LDSgud5Y
I also tried to checkout ArduSub-stable, updated and init, recursively the submodules and tried to build it.
So far the same error …
Any ideas?
Thanks and best regards,
Mike
