Hello, we are using the Ping2, as an obstacle detection sonar on a USV, and is currently mounted at 20 degrees to the horizontal. When performing different static and field tests, we noticed that when the sensor sees turbulence(for example, disturbance caused due to the USV hull, motors, etc), the confidence and distance outputs, are complete garbage. I was wondering if there is a way to fix this. We have looked at the other post regarding mounting the sensor at an angle and understand the limitations that come with mounting at an angle. I also understand, that turbulence causes issues with data, and are looking for suggestions to improve it.
The following are the results from our static and field tests, each image is a result of a scenario, as explained below
Image 1: This was performed under a static bench(Water Tub(4’ x 4’)) and provides a baseline to what is expected under normal conditions.
Image 2: In this static test case, a jet of water was initiated at one end of the tub. We already see a small deviation in data, still within an acceptable range
Image 3: In this static test, a lot of turbulence was generated, away from the sensor. The data at this point is unusable
This is a field test, where the USV was moving at its maximum speed. Again unusable data
