Is it possible to change the frequency of the ping360. I’m interested in the idea of running 2 ping360 to try some sudo 3D mapping
Ping 360 frequency change
Hi Colton,
You can configure Ping360 frequency to work with 500kHz up to 1MHz.
Check our protocol documentation here.
Note that while you can change the driving frequency in the range @patrickelectric mentioned, the transducer is a 750kHz transducer.
