I do not succeed in charging one of my 3 batteries anymore. When I plug it to the BR2 charger, no matter what mode I chose (charge, balance charge, discharge etc), it outputs “Vout over” as if I had an over voltage in one of the cell maybe. I used the battery for a mission just before, it is at 15.5V roughly.
Does it mean this battery is dead? What can I do otherwise?
It is recognized as a 3S indeed when I plug the balance charge wires. I figured out I can still charge it in normal charge if I unplug the balance wires.
I advise against charging without balancing, as on the long term it could overcharge some of the cells.
You probably had a wire of the balancing plug damaged. it may be fixable.
Yes we soved it by cutting the connector on the faulty cable and solding it back in the JST xh connector. But I have got now a new problem as I have oxydation on the negative pole and on 3 out of the 4 balance connectors after I use dit on a dive, cannot explain why, some current leak somewhere I guess, maybe because of a bad solding I have no clue.
