Hi there,
I’m trying to run the navigator lib on a raspberry pi 4 without using BlueOS. The raspberry is running a 64bit architecture and after installing the newest raspi OS I already reverted back to the recommended one, as described in Downgrading BlueOs Kernel.
I also followed the last step described in the ReadMe.
I build the simple .cpp with this command: cmake -B build -DCMAKE_BUILD_TYPE=Debug && cmake --build build --config Debug --parallel
However when running the simple.cpp I get the following error message:
Navigator C test, system details:
System is Linux on aarch64 hardware
OS Release is 5.10.33-v8+
OS Version is #1415 SMP PREEMPT Fri Apr 30 15:53:26 BST 2021
Initiating navigator module.
thread '<unnamed>' panicked at 'called `Result::unwrap()` on an `Err` value: Io(Os { code: 2, kind: NotFound, message: "No such file or directory" })', /home/auv/.cargo/registry/src/index.crates.io-6f17d22bba15001f/navigator-rs-0.4.0/src/lib.rs:280:45
stack backtrace:
0: rust_begin_unwind
at /rustc/c373194cb6d882dc455a588bcc29c92a96b50252/library/std/src/panicking.rs:578:5
1: core::panicking::panic_fmt
at /rustc/c373194cb6d882dc455a588bcc29c92a96b50252/library/core/src/panicking.rs:67:14
2: core::result::unwrap_failed
at /rustc/c373194cb6d882dc455a588bcc29c92a96b50252/library/core/src/result.rs:1651:5
3: core::result::Result<T,E>::unwrap
at /rustc/c373194cb6d882dc455a588bcc29c92a96b50252/library/core/src/result.rs:1076:23
4: navigator_rs::NavigatorBuilder::build
at /home/auv/.cargo/registry/src/index.crates.io-6f17d22bba15001f/navigator-rs-0.4.0/src/lib.rs:280:19
5: bluerobotics_navigator::NavigatorManager::get_instance
at /home/auv/navigator-lib/src/lib.rs:46:28
6: init
at /home/auv/navigator-lib/src/lib.rs:188:5
7: main
at ./simple.cpp:26:7
8: __libc_start_call_main
at ./csu/../sysdeps/nptl/libc_start_call_main.h:58:16
9: __libc_start_main_impl
at ./csu/../csu/libc-start.c:360:3
10: _start
note: Some details are omitted, run with `RUST_BACKTRACE=full` for a verbose backtrace.
fatal runtime error: failed to initiate panic, error 3245090464
Aborted
I have no experience with rust but following the error, I found that ‘/dev/i2c-4’ is to be unwrapped. However, in my /dev folder the only i2c devices are i2c-11 and i2c-12.
Does anyone have an Idea how to debug this further?
