Hello. I’m Takuma.
The other day, I got a T100 thruster and a basic ESC in Japan.I wanted to get it and check the operation right away, but my T100 didn’t move.
I confirmed many times that my program and wiring were wrong, and diverted a program that had been answered in this forum in the past. I think there are all right, but T100 does not move.
While investigating, I made a discovery. Several people say that a beep sounded when the T100 / ESC was turned on. But my T100 does not emit any sound. Is this something related? Is there anything that can be considered as a cause of T100 not working?
I recommend verifying your hardware (Thruster and ESC) first if you are having startup issues. Use a servo tester or Thruster Commander to verify that your Thruster and ESC are good.
Twisting and taping wires together isn’t very secure, I recommend something like screw terminal or electrical connectors.
After you verify your thruster and ESC are good, your software program may need work.
When the ESC starts up, do you hear the startup beeps? It looks like you’re using pifferent power sources, make sure you have a common ground between you control system power and ESC power.
Hi ! Thank you for your reply !
I tried the advice of two people, but the thruster did not move.
However, because I had little time left, I bought a basic ESC again, considering the case where the ESC was out of order.
The new ESC worked without any trouble… I may have been unlucky…
Thank you for answering !
