Could someone kindly help me?
I am using the sensor from Blue Robotics MS5837-BA
I’ve tested this sensor many times on the raspberry PI and it works great.
But when I go to ESP32 I always have some kind of problem.
My problems are related to initialization and sensor reading.
It just doesn’t work or gives a completely out-of-range reading.
The worst thing is that it’s not always, sometimes it works perfect.
I’m using this microcontroller: WT32-ETH01
I’ve tried everything to stabilize the readings. I’ve added 1K and 10K pull-up resistors and I’ve also tested without a resistor.
I can’t find a pattern that works well without going offline.
Is there anything I can do in the code? What can improve this situation?
void f_SetupSensor(){
if (!Modo_LeitorRS485){
Wire.begin(2,4);
AtivarSensor = true;
while (!sensor.init()){oErro.insertErro(10);}
sensor.setModel(MS5837::MS5837_30BA);
sensor.setFluidDensity(1029); // kg/m^3 (freshwater, 1029 for seawater)
This microcontroller doesn’t have a standard i2c port so I have to choose which port I’m going to use.
void f_SlaveSensor(){
if (AtivarSensor){
sensor.read();
oRS485.prof = oConf.round2(sensor.depth());
if (oConf.Confere_Prof(oRS485.prof)){
Sensor_ok = true;
push(prof_Array, oRS485.prof);
oRS485.pressu = sensor.pressure();
oRS485.temp = sensor.temperature();
oRS485.prepPubli();
printSensor();
if (AtivarMQTT){
f_publica(PubTopic, oRS485.prof_C);
f_publica(PubTopic2, oRS485.temp_C);
if (AtivarRS485){
if (oRS485.f_LerSerial() == true){
RS485_ok = true;
//displayOled(prof, pressu, temp);
oRS485.prepEnvio();
oRS485.f_Envia(oRS485._prof);
oRS485.f_Envia(oRS485._pres);
oRS485.f_Envia(oRS485._temp);
}else{RS485_ok=false;}
}else{
oErro.insertErro(12);
oRS485.prof = 0;
oRS485.pressu = 0;
oRS485.temp = 0;
Sensor_ok=false;
