MS5837.h, Arduino, and Wire.h - how to specify which I2C to use?
In case anyone’s interested, I just ended up modifying the MS5837 library itself (and also replaced the “Wire.h” library with the more Teensy 3 I2C friendly “i2c_t3.h” library).
The only thing I changed was to pass i2c_t3 objects as arguments for the init() and read() functions to replace “Wire” with the argument name (to be declared in the actual Arduino code).
For example, in MS5837.cpp, I changed…
MS5837::init() {
Wire.beginTransmission(MS5837_ADDR);
to…
MS5837::init(i2c_t3 WireNum) {
WireNum.beginTransmission(MS5837_ADDR);
And did the same for all instances of Wire.xxx() in MS5837.cpp. Now in my Arduino code, when I would have called…
sensor.init();
I now call…
sensor.init(Wire);
This allows me to instantiate different MS5837 objects and communicate with them via Wire, Wire1, Wire2, or Wire3 respectively.
I also added the “Arduino.h” header to at least one of my source files along the way - can’t recall which… but worth noting.
Much easier than expected!
