Micro circular bulkhead connectors with M10 threads for BlueROV enclosures now available
We are now selling micro circular bulkhead connectors with M10-1.5 metric threads to suit Blue Robotics enclosures. They are available in 2,3,4,5,6, & 8 pin male and female, plus we also have 8 pin bulkheads available with cat 5 cable.
They are made from anodized aluminum so they won’t cause electrolysis like brass or stainless connectors.
We’ll be selling them on Amazon along with our battery multiplier circuit board
Contact me directly if you’re interested in getting some before they get posted to Amazon.
@gcelec My question is how large are the bulkheads compared to a BlueRobotics penetrator? My concern would be if they can fit next to one and other with the layout of a 14 or 18 hole 4" tail plate. Additionally do they have a O’Ring base?
They won’t fit in every hole in an 18 plate, but there are 3 locations where they do fit between Blue Robotics penetrators.
They do have an o-ring base.
@gcelec Interested, pm’d.
What’s the depth rating on these?
7000m, 10,000 psi
Very cool, what’s the pricing like? Have you tested the ethernet speed through them?
Roger, good to know. Are you planning on keeping these in stock?
@gcelec Are you only offering the bulkhead connectors or also pigtails? If only bulkhead connectors, can you confirm which pigtail connectors i.e., on end of tether that these are compatible with. They look like Seacon but wanted to confirm compatibility.
Best regards
Matt
Yes I am planning on keeping them in stock but the first batch have nearly all been allocated so it will be about 3-4 weeks until I get more stock.
I can’t do pigtails cheaper than Seaconn or Subconn, but I can do custom cables quicker they they can do them.
They are compatible with the Seaconn and Subconn micro circular series of cables.
Nice!
What is the price for these 8 pin bulkheads?
MCBH8M-SVS-M10
Micro Circular Bulkhead Connector, 8-pin, Male, Aluminum, 1 ft. long wire, M10 thread
$164.99
MCBH8F-SVS-M10
Micro Circular Bulkhead Connector, 8-pin, Female, Aluminum, 1 ft. long wire, M10 thread
$185.99
MCBH8M-SVS-M10-CAT
Micro Circular Bulkhead Connector, 8-pin, Male, Aluminum, 2 ft. long wire, M10 thread, CAT5e cable
$174.99
MCBH8F-SVS-M10-CAT
Micro Circular Bulkhead Connector, 8-pin, Female, Aluminum, 2 ft. long wire, M10 thread, CAT5e cable
$199.99
Hi, following this because its an intresting topic.
I just ordered and already got my AMRONITNL connectors - i choose the MCIL2M & MCIL2F becasue i think they should be fine with my slim tether - 2 pins and 1 to make sure i do nit plug it in the wrong way.
Not i do not have an pre-drilled penetrator. is it okay to just drill an 8mm/6mm hole throught the penetrator?
how deep should i drill the 8mm hole - for the two wires the 6 mm for the rest should do the trick.
i already printed the potting part mentioned here or in another post and ordered my scotchcast 2131.
any ideas ot tipps are welcome.
thx
Didi
Do these connectors still exist? Who is the manufacturer?
www seaviewsystems.com
info@seaviewsystems.com
