Max Detection/Identification Range of BR-100126 Low-Light Camera (Above & Underwater)?
What is the maximum distance at which an object can be visually identified using the Blue Robotics Low-Light Camera (BR-100126), both in above-water (terrestrial) conditions and at various underwater depths?
I’m interested in understanding the camera’s effective visual range in both scenarios. Any practical experience or estimation based on its specs (e.g., resolution, FOV, sensitivity) would be greatly appreciated!
Hi @HudsonLe -
Your question is entirely dependent on the water quality the camera is in! If used in air, the camera can see features at a great distance away, just like the human eye (thousands of feet or more, if the object is sufficiently large.) In water, turbidity conditions typically limit visual range, with the clearest waters providing 50 to 100 foot visibility. Where the camera excels is low-light performance, where detail can be resolved without external light sources in depths of 30-50m - again depending on water turbidity, which determines how much light is present at these depths.
What sort of object are you trying to identify? Would a sonar be a better option for your application?
