hello there,
I’m trying to add control over 2 additional T200 motors in a BlueROV2 heavy.
I’m still working with QGC and I’m trying to understand the best way to set this up together with BlueOS.
First, I should say that I noticed strange phenomena in BlueOS PWM outputs page, in parameter editor under servoX_function, its seems like that the drop down list is changing from time to time when I go in to choose a function from this list, sometimes displaying values that I haven’t seen before, I’m not sure if it related to the data not acquired fully when loading blueos or some other reason.
I managed to assign mount_pan (that by the way later changed its name by itself to mount_yaw) and control one of the additional thrusters this way ,but I’m left with no other relevant pre-defined function for the 2nd thruster.
I tried to configure servo1 & 2 for this task but something either seems to be colliding between QGC and BlueOS or, more likely, I’m not doing it the right way.
I’ll be happy if you could assist with this one. Thanks!
