Hi team!
Will the M10 penetrator except a 9mm tether and seal correctly?
Hi team!
You just need to shave off the jacket until it fits in the second bore, but make sure to leave as much jacket as you can. Also, don’t make it too tight, because you need to lift the tether up and down a little bit so the epoxy makes it into the third bore a little bit. Not so much that it’s dripping out the bottom, but into that area a little. That’s how I’ve done it with 8.6mm tether.
Thanks Corndog! Great idea to keep the seal intact.
