Hi ,
Can anyone help me to know the backup capacity of Lithium-ion battery by discharging process using balance charger?
Hi ,
Hi @sudheeshk ,
I’m not sure I understand your question, can you please restate it? What do you mean by “backup capacity”?
-Adam
I believe he is trying to know the capacity of each battery. Generally as we do multiple charge - discharge cycles then the endurance of operations reduces as battery capacity reduces. Wanted to know standard methods to benchmark all the batteries to plan replacements etc…
Hi @sudheeshk and @kappa,
I see, understood. To determine the present capacity of the battery versus the original rated capacity, you should use the same method that Samsung uses to rate the cells. As far as I can gather from the datasheet, the method they use to rate the cells at 3000 mAh is as follows:
Note that the ambient temperature and charge/discharge rate during the test can have a significant impact on the result, so the above method should be used for a totally accurate comparison.
There are some good graphs showing cycle life and how discharge rate affects usable capacity of the cells in the datasheet.
-Adam
Thanks for your reply Adam.Can we do this test using Blue robotics Battery Charger/discharger ?
thanks
