Is there a way to save/copy Cockpit settings?
I am sure there is a way, but I just have not found it yet - how do I save Cockpit settings to an external drive, so I may pop said drive into another device and populate it with my settings?
Hi @3dMB -
Cockpit is designed to make moving of settings as you describe that unnecessary! If you’ve setup a user profile, those settings are saved on the vehicle, and on your computer, and sync’d based on which has the newest timestamp. If you connect a new computer to your ROV, simply select your user and all the settings should populate automatically! The only catch is that new device may initially use a different user profile, and you need to switch to the one with the name you’ve been using… Does that make sense?
Thanks @tony-white - You are saying that the settings remain with the ROV, I am saying that as an operator who uses multiple ROVs, is there a way for me to take my settings with me from one ROV to another?
If you go to Settings / General via the Cockpit sidebar (when connected to a vehicle other than the one you set up), you should be able to choose the user you normally use and get the interface and joystick setup and whatnot as usual
Hi @3dMB -
That is only part of what I’m saying!
I use many different vehicles, ROV and BlueBoat with Cockpit. I keep the same user profile on all of them. This user profile keeps a different set of settings, on a per-vehicle basis. These settings are stored both on the vehicle, and in Cockpit’s files. When I connect to a vehicle, it recognizes the ID of it, and after ~60 seconds, changes all the Cockpit settings specific to that vehicle / user profile combination. It uses the latest version of the settings, so if another user made a change using that vehicle and my user profile, it will be sync’d when I connect. Conversely, if I change a Cockpit setting without being connected to a vehicle, it is updated in the vehicle profile of whatever I was last connected to, and when again connected to that vehicle it will sync to be stored there. That way, if I lose my laptop, I can still get back all the settings from each vehicle, simply by selecting my profile once connected as Eliot mentions.
So if I go to use someone else’s ROV setup, I need to either:
  1. connect their laptop to my ROV with my settings on
Or
  1. connect their ROV to my laptop with my settings on
There is not a simple parameters file that could be emailed or put on flash drive?
Hi @3dMB -
If you use someone else’s ROV, you can either
  1. Select their user profile to get the settings they prefer configured into your instance of Cockpit
  2. Select your user profile to migrate the settings of the vehicle you last connected to, to this new-to-you vehicle’s Cockpit interface.
The parameters file is sync’d on its own - @rafael.lehmkuhl can go over the logic of this, but generally the goal was to make moving files around unnecessary!
@3dMB you can actually go to /menu/settings/general and click the “Manage Cockpit Settings” button. This will open a window where you can select a user + vehicle pair and download it’s configuration file, to be shared. One can import your settings from this same window.
PS: if you never changed the name of your user, I advice you to click the “Manage users” button (in the same /menu/settings/general config page), enable the “admin” switch and click to create a new user. That will copy the settings of the current user (which is the default named “fallback-user”), so it’s easier to share with other people without overwriting other’s people “fallback-user” settings.
I recognize there’s no intuitive way to do this kind of thing today, so I’m working on some changes to make the process easier.
