Introducing the Seascape Subsea Waterproof ROV Hand Controller
Hey all, Sietse here from Seascape Subsea!
We’re excited to announce the initial release of the Seascape ROV Controller, a fully waterproof hand controller designed to deliver unmatched precision, reliability, and ease of use for underwater ROV operations. Designed specifically for the BlueRobotics BlueROV2, this controller will be available for pre-orders at a price of €1410 excl. VAT. The expected delivery of the new batch will be in 2 to 3 weeks from now on!
Built with professionals in mind, the Seascape ROV Controller sets a new standard for ROV control. Its ergonomic design, robust waterproof construction, and intuitive layout make it the perfect choice for demanding underwater missions.
Purpose-Built for Professionals: Unlike standard game controllers, the Seascape ROV Controller is waterproof and features a rugged, durable design.
Advanced Controls at Your Fingertips:
  • 15 programmable pushbuttons for easy access to critical functions.
  • A 3-axis joystick for smooth and precise control in all directions.
  • An analog thumbwheel with spring return to center for throttle control.
  • Two rotary switches for optimal light and gain adjustments.
  • Plug-and-Play Compatibility: With a simple USB connection, the Seascape ROV Controller works seamlessly with any PC, requiring no additional setup.
  • Perfectly designed front panel for pairing with the BlueROV2.
Designed to withstand extreme conditions, the Seascape ROV Controller is the ultimate companion for the BlueROV2, ensuring responsive and reliable performance for underwater inspections, deep-sea exploration, and maintenance tasks.
From navigating challenging environments to performing intricate manoeuvres, this controller gives you complete confidence in every mission.
Technical Highlights:
  • Compact and Durable: Measuring 195 mm x 113 mm x 115 mm and weighing just 627 g, the Seascape ROV Controller is built from tough PA12 (Nylon) and meets IP65 dust- and weather-resistance standards (excluding the USB connector).
  • Generous Cable Length: Comes with a 2.8 m cable for flexibility in your setup.
  • Customizable Options: Standard USB 2.0 connection, with alternative connectors available upon request.
The Seascape ROV Controller is the ultimate tool for professionals who demand a more rugged and reliable alternative to standard game controllers for their BlueROV2.
For more info and the complete Datasheet, please visit our website: https://www.seascapesubsea.com/product/rov-hand-controller/
or feel free to reach out to us at info@seascapesubsea.com!
Great layout! I like how you recessed the main control stick. What do you normally assign the buttons on the top of the stick to?
Hi @sietse, cool product - thanks for sharing! :smiley:
If you’d like to add built in support for it in Cockpit (including visual configuration), you’re welcome to submit a pull request with the relevant values and SVG file. There’s an example here if that’s of interest :slight_smile:
Hey @kevink and @EliotBR!
The two buttons on top of the joystick could be assigned to whatever you’d like them to do. We used them for activating Lua Scripts for example!
We’re happy to submit a pull request for the values and SVG! I’ll make sure to take care of it as soon as possible.
I’m happy you guys like the design!
