I have 4 lumen lights and i just purchased 2 more light and i will attach the additional 2 lights with existing 4 lights but i was not sure how to connect red, yellow and black wires to the socket. Do i push the wire into the slot? how to identify which wire go into which slot? do i connect the wire into the same slot orientation as in the other side of the PCB board?
Hi @noppita,
This post is likely worth a read:
The slots are labelled on the PCB with silkscreen (white text), but for your reference
- the yellow (signal/PWM) wire goes closest to the edge of the board
- the red (power) wire goes in the middle of the connector
- the black (ground) wire goes in the remaining slot, at the edge of the connector that’s closest to the middle of the board
