Hi guys,
Iv taken apart the lumen lights so that I can trim the cable length so fit my ROV a bit better.
When Iv gone to put the wires back into the splice connections it looks like a dog has chewed on it and not like the nice neat wiring that was in there. Are you using a special tool to push the wires into the splice connections or do I just need a bit more finesse ? I’m just pushing them in with a small screwdriver.
I had to do something similar when putting lumens into my latest design and ended up using a small screwdriver as well. As you mention, it is far from a perfect job. One of my lumens never worked after I did it so possibly forcing the wires in by force has to be done with quite a bit more care than I used.
The connectors are designed to use with this tool. As @johng and @Tangaroa mention, you might be unsuccessful or even cause damage without this tool. Without the tool, it might help to place some wadding like folded up paper towel over the wire before pushing it in order to get some conformation and even pressure application.
