Hi @Matt_D,
You can try setting the SERVOn_TRIM parameters for your motor pins to be 1100, with MOT_PWM_TYPE set to PWMAngle (9).
That said, @tony-white is correct that ArduSub expects to be using reversible motors, so I’m unsure whether that will actually work properly / as expected, and am similarly curious what your application is.
