How can i connect blueOs to qground control
good evening, i have read the documents over and over again but i couldn’t understand how am i going to connect blueOs to qground control can someone help me for that please im racing with time
Hi @lena -
BlueOS connects to QGround Control via a TCP/IP link. Your control computer and the BlueOS device must be on the same network, then your control computer can receive the Mavlink telemetry and Video stream targeted at its default IP address of 192.168.2.1. You can reach the BlueOS interface at blueos.local or 192.168.2.2.
Can you share what documentation you’ve reviewed and what you still may be struggling with?
Thanks, and welcome to the forums!
Hi , thank you for answering. İ didn’t use the blueOs before and blueOs documentation is a bit confusing to be honest it’s says pirate mode but i can’t see something like that in the New version. And as i readed some questions in this forum i relized some people talks about compute ip adress how can i change that. İf it’s alright can you lead me step by step? İm not good at this tbh i usually work in the electronics part but my friend denies to work so i have to do this somehow
Hi @lena -
Pirate mode is accessed via the smiling robot icon in the upper right hand corner of the BlueOS interface.
You need to configure your computers IP address on the network adapter you’re using to connect to it - this is usually the USB to Ethernet adapter in the FXTI. You can find instructions for that here.
