Hi everyone,
I’ve been working on a power distribution board for medium and larger ROVs, and I’d like to share the current concept and get some feedback from the community.
For now, the project is called Nexus — this is still a working name.
The idea came from wanting to simplify high-current power distribution inside an ROV. Instead of having multiple heavy cables, separate distribution points and additional DC/DC converters scattered around the enclosure, I wanted to integrate the main power distribution and low-voltage power into one compact module.
The current concept includes:
high-current battery input,
8× ESC outputs, up to 32 A per channel,
2× payload power outputs, up to 32 A per channel,
approximately 200 A design target for the main power path,
Hall-effect current measurement up to 200A,
battery voltage monitoring,
two separate 5 V / 6 A DC/DC power domains,
dedicated power for the Navigator / onboard computer,
a separate 5 V domain for payloads and accessories.
The two 5 V converters are intentionally separated. The idea is to keep the compute / control electronics on a separate power domain from payloads, cameras, sensors and other accessories.
Current and voltage measurements can also be passed to the Navigator, so the ROV can monitor the main power system during operation.
The high-current section is designed around solid copper busbars rather than relying only on PCB copper for the main current path. The busbars are not visible in the current renders, as they are located directly above and below the PCB.
This is still a prototype and the electrical and thermal limits have not yet been fully validated. One of the next major steps will be high-current testing at around 150–200 A, including temperature measurements of the busbars, PCB connections, terminals and current sensor.
I’ve attached a few renders of the current mechanical concept together with a simplified block diagram.
I’d be very interested to hear what you think about this approach to power distribution inside an ROV.
Is there anything important you think I’m missing, or any feature that would make this kind of module significantly more useful in a real ROV?
The goal at this stage is not to present a finished product, but to make sure I’m solving the right problem before finalizing the design.
Any criticism or suggestions are very welcome.
