For Sale: BlueROV 2 Heavy Fit Outfitted for Cinema Camera + Tons of Extras (Monterey, CA)
For sale is this Blue Robotics BlueROV2 with heavy fit and tons of accessories.
Google Drive Photos
It has been outfitted with the ability to operate, monitor, and control a separate cinema camera underneath the vehicle (camera and housing not included but negotiable).
  • Asking $6800 for everything. Make an offer.
  • I used a Z Cam E2S6 but it should be functional with any camera that utilizes an ethernet control.
    • Operation with the camera uses the same tether as control as the vehicle, and therefore no separate tether is required.
    • Camera control and vehicle control operate independently on the surface. I can share some video that I have shot with this.
  • I bought this used and It comes with a TON of extras, much of which has never been used and probably isn’t pictured because Facebook doesn’t allow enough photos.
    • Multiple (3) tethers including one that is 300m (possible 500m? hard to tell) and others that I think are 100m but again I’ve never extended them all the way.
    • 3 batteries,
    • claw,
    • vehicle lights
    • and so much more.
    • See photos.
  • Pick up in Monterey, California.
    • Could possibly meet at a reasonable distance.
Hello Connor
I’m interested if you’d be willing to ship to UK?
Best Regards
Jack
Connor,
Can you list everything on the ROV, interested in buying it. Also, Is internal camera a BlueRobotics 1080?
Hey Jack,
I likely would not be interested in international shipping as it’s so much stuff. It would have to be fully organized on your end and paid for I’m not sure it really makes sense? Willing to consider
Hi Mark,
confirming the large spool is 550m of tether (since I was unsure when I first made this post)
Here is a list of everything when I originally bought it before fitting it with the cinema camera. Some consumables are a little different at this point but see the Google Drive Photos for exactly what’s included.
Fathom Spool w/200m Fathom Slim Tether
Heavy 8-Thruster Upgrade
1ea OEM Battery +2ea DIY Batteries
SkyRC iMax B6AC Charger
4 Lumens
Newton Gripper
Aluminum Electronics Tube
Aluminum Battery Tube
Peek Bar100 Depth Sensor
RMG 2-pin Tether Quick Disconnect
Just updated companion to 0.0.28 and ArduSub to 4.0.3
Large Custom Tether Spool w/550m 7mm OD 22awg single twisted pair of foil shielded tether. Electrical resistance is less than 300m of the standard BR tether. Would be great for a Tahoe drop cam.
Full Custom Frame w/Integrated Skid, also includes standard side panels, all custom made, but basically identical to BROV2, all interchangeable.
Custom Tether Spool smaller than Blue Robotics Fathom with ~120ft of Fathom Slim tether. Fits inside Nanuk 920 case, which I have and can include.
Same spool as above w/o tether.
2" Camera bottle, which I was going to stick a GoPro Hero 5 Session inside of, which I have and have begun disassembly. Can include camera, or sell bottle by itself.
8ea Replacement Thruster Nozzles, 8ea Flat Surface Thruster Mounting Brackets, 6ea Standard Buoyancy Covers, 4ea Middle/Heavy Buoyancy Covers
Spare Epoxy, Penetrators, Deck Cables, New Vacuum Pumps, Misc.
Thanks Connor, think I’ll pass and good luck with sale.
Hello
I am interested in the ROV, is it still available? We are based in NJ and we carry out technical inspections for ships and offshore structures
Very respectfully
Ayman
