Like new, only used in a test tank, but that will probably change within the next week or so, since I’d like to take it out to make sure it’s all working nicely for the new owner. Should be everything you need, save for a laptop. Asking $4000. Located in Northern California.
- Fathom Spool w/200m Fathom Slim Tether
- Heavy 8-Thruster Upgrade
- 1ea OEM Battery +2ea DIY Batteries
- SkyRC iMax B6AC Charger
- 4 Lumens
- Newton Gripper
- Aluminum Electronics Tube
- Aluminum Battery Tube
- Peek Bar100 Depth Sensor
- RMG 2-pin Tether Quick Disconnect
- Just updated companion to 0.0.28 and ArduSub to 4.0.3
Some optional accessories below, will offer good deals if purchased with the ROV…
Large Custom Tether Spool w/550m 7mm OD 22awg single twisted pair of foil shielded tether. Electrical resistance is less than 300m of the standard BR tether. Would be great for a Tahoe drop cam.
Full Custom Frame w/Integrated Skid, also includes standard side panels, all custom made, but basically identical to BROV2, all interchangeable.
Custom Tether Spool smaller than Blue Robotics Fathom with ~120ft of Fathom Slim tether. Fits inside Nanuk 920 case, which I have and can include.
Same spool as above w/o tether.
2" Camera bottle, which I was going to stick a GoPro Hero 5 Session inside of, which I have and have begun disassembly. Can include camera, or sell bottle by itself.
8ea Replacement Thruster Nozzles, 8ea Flat Surface Thruster Mounting Brackets, 6ea Standard Buoyancy Covers, 4ea Middle/Heavy Buoyancy Covers
Spare Epoxy, Penetrators, Deck Cables, 2ea New Vacuum Pumps, Misc.
