Fathom-X Tether Interface (FXTI) Connection Details
Hi
I have recently purchased a Fathom-X Tether Interface (FXTI) and a couple of the Binder Plugs to go onto a couple of existing tethers (I have a BIRNS Aquamate Connector down on the ROV)
As I have both Cat 6 and Slim tethers I was just looking for a Standard wiring diagram for the pin connections on the Binder to the FXTI to try and make the system uniform (future proofing) similar to what you are doing with the short jump cable from Fathom Spool to the FXTI
Scott W
Hi Scott,
You can see soldering instructions with our standard pin/wire connection order in the documentation.
-Adam
Thanks Adam
Hey, I tried accessing the link. But it was removed. the page no longer exist.
its 2023, and I’m having the same problem. Is there a resource page where I can find the solution to this problem?
In general I’m having trouble wiring BlueROV2 entirely. Any help is greatly appreciated.Thank you.
Sincerely,
Sajjad Sharif.
Hi @sajjadbsharif, welcome to the forum :slight_smile:
I’ve updated the link in Adam’s post, so it should work as expected now.
Note that we also sell ROV ready tethers, which come with the relevant connectors already attached.
If you aren’t already, I would suggest following our BlueROV2 Assembly Guide, which covers the hardware and wiring components of getting started with a BlueROV2 :slight_smile:
