Fathom to Arduino Serial Connection
Hello!!!
I have been looking for information but I have not seen a clear guide,
I need a connection from above, out of the water, to the ROV. I only want a Serial connection, from outside a computer or arduino to the ROV with arduino, the idea is to have a Serial communication to send data and receive, I only want to send data, I don’t need video.
I have been reading that you use FATHOM but some concepts are not clear to me,
  • What combination will I need???
I understand that above I would need FXTI , it has a connection for Binder 770 and a USB output that I could connect to the USB of my laptop and read through the arduino IDE serial the data that comes to me from the ROV’s arduino.
In the ROV part, I would need another Fathom X board and from there connect to the Arduino serial port to have communication with the surface. Correct me if I’m wrong.
Thanks!!!
If you just want serial data, it would probably be easiest to utilize a second twisted pair in the tether and use a pair of RS485 converters to connect to the Arduinos.
If you want to use the Fathom it would probably be best to add an ethernet switch (https://bluerobotics.com/store/comm-control-power/tether-interface/ethswitch/) top and bottom and use an ethernet shield on the Arduinos instead of using the serial ports.
Thanks!!!
So it is much easier than I thought! The FATHOM board would be useful if you need video but since it is not my case, I understand that following this attached diagram and using the standard cable https://bluerobotics.com/store/cables-connectors/cables/cab-nbpuf-4utp-26awg / and RS485, it would only use two twisted pairs and it would already have serial communication.
Thanks!!!
