Just checking- can you do an enclosure with a dome on both ends? I see they want you to vent the enclosures, but I imagine you can’t do that in this case? Would that be okay to not install a vent if that’s the case?
Hi @LiveForLiving -
You could certainly hold the domes on long enough to insert the locking-cord on the flange they attach to, or assemble it and bolt on the dome afterwards for minimal air compression inside. However, with dual domes you would need a custom endcap flange if you needed to bring any cables into the enclosure!
