Control BlueROV2 with iPad
Can you tell me more… do you see joysticks if you touch lower half right or left?
And please update the app. Yesterday I released an update.
Hello Grega,
i downloaded the update but now i can’t see the video that i could see yesterday. Yesterday I was able to see the video and i had both joystick showing on the screen but no command for them.
Now i have all the functions working (tilt up/down, jaw o/c and lights dimmer) but i can’t see the video and the thruster are still not working. With my laptop all is fine as usual. Also the altimeter is working. What could be the issue ?
Thank you
Andrea
What version of ardusub do you have? The new BlueOS?
Yeah i have the last version.
Any idea ?
Thank you
If you have the last version of BlueOS than you can also check under Vehicle Video if you see stream of main camera and if it is set to udp port 5600?
I will post an update in day or two. Please try then.
And thank you again for your feedback.
Grega
Hello Grega,
thank you for that ! I will definitely try it, i need the i pad as a back up for now and possibly for a future primary configuration and therefore i am very interested to test it.
Please let me know when the update is out.
Andrea
The update is on the AppStore. please try it.
Tested on Custom Prototype, the ORB, :wink: passed all test here.
Thanks inifinite for this great job.
I have just setup a generic router to the standard static Ip address like it was a PC.
From EagleRayRobotics
Costa
