Connecting PING Sonar to a Tritech Micron
Is it possible to connect a ping sonar to the 2nd port of a Tritech Micron scanning sonar to use the existing RS 485 connection of the ROV to submit the data and split out the data on the surface.
The purpose is to integrate a deepsounder to measure the distance between the ROV and the ground within an existing ROV configuration (The ROV is from ROV Bulilder and the Scanning sonar is from Tritech)
Hi Thomas,
The Ping sonar is not compatible with the Tritech Micron family of devices. I think you’d be best off with a Micron echosounder as well to make sure everything works together.
Good luck!
