Hello, I tried to connect multiple sensors to the Pi, after extensive troubleshooting, I runned a GPIO test and got the following error:
The main 8 GPIO pins 0: 7:
–> Pin 0 failure. Expected 1, got 0
–> Pin 1 failure. Expected 1, got 0
–> Pin 2 failure. Expected 1, got 0
–> Pin 3 failure. Expected 1, got 0
–> Pin 4 failure. Expected 1, got 0
–> Pin 5 failure. Expected 1, got 0
–> Pin 6 failure. Expected 1, got 0
–> Pin 7 failure. Expected 1, got 0
8 faults detected
The 5 SPI pins 10:14:
–> Pin 10 failure. Expected 1, got 0
–> Pin 11 failure. Expected 1, got 0
–> Pin 12 failure. Expected 1, got 0
–> Pin 13 failure. Expected 1, got 0
–> Pin 14 failure. Expected 1, got 0
5 faults detected
The serial pins 15:16:
–> Pin 15 failure. Expected 1, got 0
–> Pin 16 failure. Expected 1, got 0
2 faults detected
The I2C pins 8: 9: Pin 8 failure - expected 1, got 0
Pin 9 failure - expected 1, got 0
2 faults detected
I installed the BCM library and wiring gpio do you have any input? I connected the Pi with the pixhawx by the 5v and gnd pin, the software is running fine except I am not able to make the GPIO works. any help is greatly appreciated.
Regards,
Francesco
