somebody can help.
i’m new here.
i can’t connect my camera using logitech c270 at companion web and also in QGC there is no video stream.
using win 10.
thanks
Hi Ryan,
Access http://192.168.2.2:8088 and check if the camera appears under the path /dev/video* with ls /dev/video* command, if the camera appears, run the following v4l-ctl commands (application to control video4linux drivers).
First, try to list all devices:
pi@raspberrypi:~ $ v4l2-ctl --list-devices
H264 USB Camera (usb-3f980000.usb-1.2):
/dev/video0
/dev/video1
To know the format of video0:
pi@raspberrypi:~ $ v4l2-ctl --list-formats-ext --device=/dev/video0
ioctl: VIDIOC_ENUM_FMT
Index : 0
Type : Video Capture
Pixel Format: 'MJPG' (compressed)
Size: Discrete 1920x1080
Interval: Discrete 0.033s (30.000 fps)
Interval: Discrete 0.040s (25.000 fps)
Interval: Discrete 0.067s (15.000 fps)
Index : 1
Pixel Format: 'YUYV'
pi@raspberrypi:~ $ v4l2-ctl --list-formats-ext --device=/dev/video1
Index : 0
Pixel Format: 'H264' (compressed)
pi@raspberrypi:~ $ v4l2-ctl --list-formats-ext --device=/dev/video2
Index : 0
Pixel Format: 'YU12'
Name : Planar YUV 4:2:0
Size: Stepwise 32x32 - 2592x1944 with step 2/2
Index : 1
Index : 2
Pixel Format: 'RGB3'
Name : 24-bit RGB 8-8-8
Index : 3
Pixel Format: 'JPEG' (compressed)
Index : 4
Index : 5
Index : 6
Pixel Format: 'YVYU'
Index : 7
Pixel Format: 'VYUY'
Index : 8
Pixel Format: 'UYVY'
Index : 9
Pixel Format: 'NV12'
Index : 10
Pixel Format: 'BGR3'
Name : 24-bit BGR 8-8-8
Index : 11
Pixel Format: 'YV12'
Name : Planar YVU 4:2:0
Index : 12
Pixel Format: 'NV21'
Index : 13
Pixel Format: 'BGR4'
Name : 32-bit BGRA/X 8-8-8-8
The /dev/video1 will be the used by gstreamer to send the H264 to QGC.
You don’t need to change nothing in the code to make the camera configuration page to detect your camera if it supplies a H264 stream. Do you have any documentation of this camera ? I was unable to find in the logitech website any encode information.
Hi Patrick,
after i execute this command :
Index : 0
Interval: Discrete 0.050s (20.000 fps)
Interval: Discrete 0.100s (10.000 fps)
Interval: Discrete 0.200s (5.000 fps)
Interval: Discrete 0.133s (7.500 fps)
Index : 1
the camera does’nt support H264
is it possible if convert from current format to H264 ?
Hi @ryan354
Hi, Have you tested it out by plugging it directly into a Windows 10 PC? I used a Logitech c270 webcam to build the “Jet” robot using a NVIDIA Jetson TX1 and it blew/overheated the entire camera even though it was safely plugged into the Jetson’s USB port. in the end, the logitech c270 could still be recognized as a camera by my computer but the camera’s video stream was completely dead and fried.
This might be the issue if you are able to connect the webcam but the video feed just turns up a blank black screen. If that’s the case, I suggest you buy a Logitech B525 HD Webcam which is almost as cheap as the c270, because it doesn’t overload as easily as the Logitech c270. Also, with small logitech webcams like these, they are usually designed to be used for around ±30mins to ±1hr so don’t leave the webcam plugged into the running device for too long even if you are not using its video stream as they will easily overheat and break (like what might have happened to your logitech c270)
Regards,
@Tamanya
this is the a screen shot of what happens when I connect the c270
I was using the B525 to take those images.
Here’s the link to buy the logitech B525: https://www.logitech.com/en-us/product/b525-webcam
Hi Ryan,
Yes it is possible, but you’ll have 2s+ delays in the video and can be much more worst if the processor or the system start to hangs (high cpu temperature and power consumption).
But… If you really really want to use it, you’ll need to study gstreamer pipelines and read some good documentation to build your own gstreamer pipeline, start with x264enc, but the final result will not work as the way you want.
Hi, Xavier.
Now i consider again to buy raspicam or other camera.
thanks for information.
Hi patrick,
i think that’s not good enough for streaming.
maybe i should buy a new one.
Hi Ryan,
No problem, let us know if you need any further help.
oh, ryan
try the Pixy camera
its cheap and can do remote stream it can also pan and tilt which is gr8
