mohan
(kumar)
1
We are encountering communication getting lost in around 2-3 minutes after the dive.
Observations:
Core temperature In BluOS software is 51’ celcius
and in qground temp 1 is 48’ celcius
We are using two camera feed.
and also when it is out of water it is working only for 30 to 35 minutes.
Can anyone help to overcome this probelm?
EliotBR
(Eliot)
2
Hi @mohan, welcome to the forum
It’s hard to give meaningful advice with so little information. Could you please specify:
- What hardware are you using?
- Is your flight controller a Pixhawk or Navigator?
- Are you using our USB cameras, or something else?
- Are you on a Raspberry Pi 3B or 4B?
- Are your power supplies sufficient for the loads involved?
- Battery capacity and 5V regulator capacity
- Is the connection loss temporary (i.e. does it return), or is it permanent?
- What BlueOS, ArduSub, and QGroundControl versions are you using?
