I was just wondering if anyone has ever referenced or cited QGroundControl in an academic paper? I see most references in the literature refer to the user guide, like this:
I refer to it as an open source software, and I haven’t found any other conventions for citing it yet. If anyone has any recommendations please let me know! Many thanks
This isn’t something I’ve looked into much, but I would assume the citation contents should depend on the way in which you interacted with the software.
As a few examples:
if you were using it as a tool, where you were a standard user, then linking to the software’s website homepage and mentioning things like the version used would likely be relevant
This university site describes the APA format for software references, which applied to QGC would be something like
Dronecode Project, Inc. (2024). QGroundControl - Drone Control (Version v4.4.0) [Computer software]. Dronecode Project, Inc. http://qgroundcontrol.com
if you were modifying the software, or using the source code as a reference, then it would make more sense to link to the code repository, and likely mention a tag or a git hash so the same state can be checked against, e.g.
if you’re referring to a specific process the software includes, then it might make sense to instead make a website reference to the relevant section in the user guide
if you’re referring to the development practices, you could consider a website reference to the developer guide
Hope that helps!
Once your paper is published, it’d be great if you could tell us a bit about it in the Research category, in which case you might get some discussion from the community, and Blue Robotics can include the paper in the Subsea Scholar section of our website
