I am planning to build underwater ROV. I have blue robotics servo SER-2021, SER-2031, SER-2001. I would like to know that
-Which controller is best for controlling that servos.
-How to connect them to controller.(like Ardupilot, Arduino, etc.)
Blue Robotics does not yet sell underwater servos. From the product codes it seems yours are from Blue Trail Engineering?
Unlike brushless DC or stepper motors, servos generally include an internal motor controller, so all you need to provide is a suitable control signal for the servo type you’re using (e.g. PWM, CAN, or serial).
As an example, the SER-2021 is apparently controlled via PWM, with 700µs - 2300µs pulse-durations. That kind of signal can be provided by most microcontrollers (including Arduino and ESP32 boards) and flight controller boards (like the Blue Robotics Navigator (+Raspberry Pi), or a freestanding one like a Pixhawk or CubePilot variant), so it’s less a question of what is best for controlling the motor (they’ll all be fine), and more about what other features you may need.
A flight controller board comes with onboard sensors for estimating vehicle orientation and movement, as well as various connectors for integrating common peripherals (like motors and other actuators, and additional sensors like a barometer for depth estimation).
Blue Robotics designed the Navigator for common ROV use-cases, and it’s likely the most used flight controller board for the ArduSub autopilot firmware. Since we make and actively use that board it’s understandably the easiest option for us to provide support for.
That said, which option is best for your ROV depends on what you’re trying to achieve, your budget and time/development resources, and what kind of functionality you need.
And also I would like to know that how to connect that servo to the controller and is there any tutorial about this servo. they have 3 pin but no head in the wire . so before i have to connect to the controller what should i prepare. Some servo come with female or male pin (with Power , GND, PWM) but in the blue trail servos , there is only wire, so what components i might need to test with the controller.
Hi @Michael17 -
Blue Robotics doesn’t manufacture the Blue Trails Engineering servo - I would suggest checking the product page for documentation, and contacting their support if you’re having issues! I saw a pinout in the datasheet that details what pin is what, but it says nothing of wire colors…
