I’m interested in knowing if its possible to change the speed of sound value beyond that of the range in ping-viewer. this is needed for diving in places where the water density is much higher. thanks.
Hi @odedezra,
If you turn on Debug Mode you should be able to set the speed of sound to whatever you want.
I just tried quickly with Python and the sensor didn’t complain to me setting 5000m/s, or 300m/s, so you should be fine ![]()
Hi @EliotBR
Thanks for the info, we’ll give it a try!
