Need to change the Density for Depth Sensor use in Salt Water. Is this done in Parameters of QGround or does it need to be changed in the Keller D Arduino program itself?
Hi @dtrail,
If you’re running ArduSub you can use the BARO_SPEC_GRAV parameter to set the water density. If you’re using a Bar100 sensor in some other project (e.g. with an Arduino) then you’ll need to use the setFluidDensity function in the library.
Thanks. I actually need to do both for two different applications.
