BlueOS Node-RED extension
One of the greatest features on BlueOS 1.1 is the possibility to install extensions and extend the funcionalities of the system.
Node-RED extension is one available in our store. There you can read data from serial ports, receive and send mavlink messages, write to a file and much more!
You can also create your own dashboard to visualize the information or send messages to vehicle or ground station.
Flow used in this example: example.json (1.4 KB)
Note: You need to install in node-red the following plugins: node-red-contrib-web-worldmap, node-red-dashboard, node-red-node-serialport
Sweet, this is big!
Great news!
I want to use a joystick to move the ZOOM on my IP camera.
Can I use Red-Node to get custom_1 input?
The IP camera can be configured for Zoom at http put.
Hi @Itaru,
You may want to try this extension:
Thank you very much.
I understood that there is also an onvif extension.
What I want to know is how to write mavlink and message.
How do I receive custom_1 input from joystic?
@patrickelectric are you able to share the Json file for the entire example flow and not just the graph node?
I was able to do this after reading the following pages.
@Itaru thanks, this is perfect - so looking forward to making use of this functionality. Great job on BlueOS, the mavlink rest api and Node-Red extension.
Is the original flow available somewhere? I am looking for info about the Websocket out part (bottom right part). This can be use to send custom command to the pilot rigth?
Flow in original post
