I’m having a connection issue where after powering the Raspberry Pi, the connection will drop after a few minutes. Sometimes there are a bunch of errors when it happens but the main one seems to be “BlueOS Frontend” being spammed until I unplug / replug the Pi.
Could this be an issue with the power supply, or overheating? Sometimes a warning pops up about the CPU being too hot (65 deg. C). Any insight would be appreciated.
Hi @urchin -
In BlueOS, do you see any red warnings on the top bar before you lose connection? How are you connecting to the Pi running BlueOS?
Generally it sounds like your browser is losing connection to the vehicle. What version of BlueOS are you running?
If this is an ROV, running on the bench for a long time with the enclosure sealed can lead to overheating, especially in warm climates. Does your system use a Pi 4?
